Awesomatix A800FX Front Wheel Drive Touring Car
#346
Please also try softer swaybars.
Awesomatix A800FX Setup Sheets
#348
AWESOME MATICS!
#350
Last Saturday I ran my FF-03RR (my rally version) against three the XV-01 rally cars at a local track. Surprisingly, I was surpassing them on straights and corners. The FF-03 was so balanced even at the jump and lands really well. Cornering was no problem except during tight hairpins but I managed to do the hairpin cornering trick so that wasn't a problem.
#352
#353
#355
Did you tryed only one ST019 in the top deck? EU guys are using now only one ST019 there with FX alloy chassis.
#357
Please be sure that you are using the proper side of top deck with recess for ST019 head and the top deck should have possibility to swing around this single ST019 without tension. If this tension exists please add small ( ~0,1mm) chamfer on the inner edge of the recess.
#358
1 ST019 screw is very effective change. For sure you should try this as well these softer swaybars.
#360
3300kV is 13,5 with 30°, 17.5 is ~2700kV, 21.5 is ~2100kV...
