Awesomatix A800FX Front Wheel Drive Touring Car
#241
that's quite heavy from my POV (because I consider that FWD should be below 1000g lol) but it should be quite efficient with 13.5
#243
Yes I have 30g of weight In the front bumper. So your running a 1s battery pack ? I'm setting up my car for this years IIC In Las Vegas minimum weight is 1300g . Do have pictures of car ready to run?
#245
I'll have to check those packs out for club racing .
#248
#250
Ok! I’ll order a couple. Thx.
#251
I usually use standard ride height gauge on a setup bord , or calipers and measure from the top of the axle , Rod showed that way .
#253
what ive done the few times I’ve used it (tho normally don’t use any set screws ) I push the car down fully compressing the car in race trim against the flat surface and adjust the screws to where they just barely touch each Aarm I want to say the idea of them is to keep the spro2 from contacting the dampiner holder I don’t really want to bend a arm either
#254
Ive always wondered what the upstop measurement was. I assume it is the screw that goes in the top of the bracket that straddles the arm and supports the roll bar. When I was playing with up stop changes i measured the distance between each thread of the screw. If it was .2mm then every revolution out is .2mm. To figure out the starting point I rant the screw all the way in until a .01 shim would drag on the screw and then I counted turns reverse turns. Didn’t seem to make much of a difference for me but i didnt spend allot of time on it. Locking the arms down with the set screw does help me measure flex if im making changes to get more or less flex.
#255
Upstop is not needed to set in my opinion.
We never run upstop with our setups as its not needed.
