Awesomatix A800FX Front Wheel Drive Touring Car
#256
I received the A800FXC kit and in the process of building. The kit has pre-filled dampers, with the instructions stating that they come with 500 cst oil. However the dampers I received, 2 seem to have a much higher viscosity oil than the other 2. The bag that the dampers came in were not marked in English, so I don't know the labeling! Can anyone tell me what the CST on the thicker damper is? I assume the other 2 are around 500 cst. Also I assumed that the "thicker" dampers would be used in the front suspension....
#257
#258
#259
Finally got to run my car today !!!
Unfortunately didn’t have a good hot hatch body tho.... the tank I had on it make it very tippy with old warn tires.
But had a blast driving it with a random assortment of usgt bodies and the tank .
I ran with the vta group first as my car had a 25.5 geared at 3.97 (motiv mc2 @44*) with the (100g)suv body and 0 added weight car was 1180 .
Vta ran 12.0 FLaps
i ran 11.7 with the fwd
got moved to usgt , I attempted to change to a Ford gt body for comparison using the 25.5 I can 11.5 with that body .
Next round I put a 21.5 (R1 v16 fdr4.16 @48*) in to try and swapped to a bitty AGATO body and managed to run 10.9 FL
the other usgt cars were running 10.9 FLaps also .
For the mains 2 others pulled there fwds out so I went back to the 25.5 motor and SUV body . But by now the tires have woke up and we’re making more grip so I had traction roll issues with the top heavy body .
Car was a blast to drive and using the 25.5 motor has a super open setup window . Built it box stock except with 40wt front oil and 25wt rear oil . Ran the rear at A0/B4 with type 2, 0toe ,0camber , 4 long caster .
Front was box stock settings .
Vta ran 12.0 FLaps
#260
I've also learned the car is very capable in the USGT class against the 4WD tourers.. One black carpet that is.. Not sure how it would fair on tarmac.
laptimes were on par with the fastest 4WD with the same USGT (Gravity) tire.. we both were just a tick slower per lap than the winner (VBC Fwd with slicks)
very happy with the first outting. solid car.
#261
Super Moderator
#263
Is it possible to convert to RWD?
#264
Has anyone tried replacing the gear diff with a spool?
#268
I have been an RC racer for over 25 years.F1 ,then TC ,then back to F1 a couple of years ago because TC got way to intensive.Wenn I saw that Xray was going to build a FWD ,I reserved one right away.Been driving it off and on (mainly racing F1) since Feb.Really nice car ,fun and easy to drive.Sold it yesterday and ordered the A800FX.The new techniques and innovations seduced me.In Germany the A800FX in allowed in all FWD series,even the TOS that is real close to ETS.The final decision not to allow the A800FX in the ETS has not been announced.The first ETS race is in Sept. ,so the decision will be announced soon.
