Aluminium or graphite for carpet? >
Like Tree15Likes
Old 11-14-2018, 01:05 PM
Default Aluminium or graphite for carpet?
I heard and read many opinions about it, still not clear. What do you recommend for a small twisty and grippy circuit?
joanplanas is offline
Old 11-14-2018, 01:50 PM
MOmo's Avatar
I've always used
Aluminum-Indoor Carpet
Carbon- Outdoor Asphalt
drover and DaSilva3525 like this.
MOmo is offline
Old 11-14-2018, 02:05 PM
DaSilva3525's Avatar
I've done the same pretty much
Carbon- Asphalt
Carbon - Grey ozite or Alum for a highly built up groove on grey carpet
Alum- CRC black carpet / ETS carpet ( I would assume on the ETS carpet as I never personally tried that carpet)
DaSilva3525 is offline
Old 11-14-2018, 04:20 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Aluminum in high grip asphalt
Marcos.J is offline
Old 11-14-2018, 05:27 PM
theproffesor's Avatar
Trader Rating: 66 (100%+)
The question is, how good a driver are you? Do you wreck often? Or generally pretty clean? Aluminum can be fairly flexible if you get the wrong one, but it is generally heavier and helps bring down the CG. You can make a carbon chassis pretty stiff with the right options. All top deck screws, center stiffener, connecting servo and motor mount to top deck.
But it what goes back to my original statement is, aluminum is great, until it’s not. By that I mean, once it bends, it’s done. Carbon can take a lot more abuse before it breaks. But unless it actually cracks, it’s still good. It only takes the smallest bit of tweak to ruin a high dollar aluminum chassis.
so choose wisely.
theproffesor is offline
Old 11-14-2018, 05:49 PM
Trader Rating: 24 (100%+)
Actually just came to post this very same question!
I swapped my Roche over to the aluminum chassis for black carpet last weekend, but am racing on the gray this weekend. Not sure if I should run the aluminum on the gray carpet or swap back to the carbon. Anybody have experience that could weigh in?
fenton06 is offline
Old 11-15-2018, 12:15 AM
I see aluminium is the way to go. I will try both the IF-14 alu one and the 7075 that is thicker (and heavier). Thanks guys!
Old 11-15-2018, 05:35 AM
jason cheng's Avatar
Trader Rating: 86 (100%+)
old school we now run titanium plates https://www.titaniumrc.com
jason cheng is offline
Old 11-18-2018, 08:17 AM
12th scale amain #1 iic las vegas stock titanium plates from https://www.titaniumrc.com #1, #3, #5, #7
Old 11-18-2018, 03:03 PM
Racer Z's Avatar
A main #2 carbon.. A main #3 carbon.. Overall win carbon.. Guess there's something to be said for old school !!
Racer Z is offline
Old 06-04-2020, 12:43 AM
Kajman's Avatar
How are things now? Is really aluminium winning on carpet? It is strange thing to me that one can't do winning chassis with lighter materials?
Kajman is offline
Old 06-04-2020, 02:15 AM
gigaplex's Avatar
There's a minimum weight requirement so most people have to add weight. It's better to add weight down low to keep the CG low. A heavier lower plate is good for that.
Aluminium is generally too stiff for asphalt, but another big reason is the alloy chassis scratches up pretty bad outdoors.
sosidge likes this.
gigaplex is offline
Old 06-04-2020, 06:28 AM
daleburr's Avatar
The two materials also have different damping qualities.
Aluminium has more natural damping, which is good on carpet where you want a less edgy car.
Carbon has less natural damping, so is more responsive, which works better on asphalt. It also has more flex, which is also better on asphalt (up to a point).
Bry195 likes this.
daleburr is offline
Old 06-04-2020, 07:01 AM
rc_square24's Avatar
For ETS carpet, I've always noticed on my carbon cars that they are more responsive but also on high speed corners and quick changes of direction it seems to be a bit unstable and noticeably flexing a lot (chassis almost looks like its fluttering).
Aluminum on the other hand the car is much more consistent, giving me confidence to push it further.
Anyone tried a thick carbon chassis say 2.5/3mm? How does it compare to aluminum on carpet?
rc_square24 is offline
Old 06-04-2020, 07:25 AM
Were those CRC cars with the super stiff Z plate carbon?
DavidNERODease is online now
