Like Tree272Likes
XRAY T4'19 SPEC
Old 05-21-2019, 08:43 AM
  #511
XSRCdesign's Avatar
That set screw in the open hole, and a slightly longer ball stud cured that issue for me.
silden likes this.
XSRCdesign is offline
Old 05-21-2019, 09:48 PM
  #512
Trader Rating: 22 (100%+)
Agreed. Use a 10mm ball stud there.
mariob62 likes this.
Troy Carter is offline
Old 05-22-2019, 02:29 AM
  #513
Lonestar's Avatar
Trader Rating: 14 (100%+)
Originally Posted by silden
We used to put a short setscrew in to the second hole. this cured the issue you have.
Thanks. As said in my note above, so do I. however if you crash hard enough though (which, well, happens...) you will rip the ballstud off no matter what: lots of leverage there with the ball sitting like 7 or 8mm above the plastic with the standard 4mm shim. Not complaining, makes perfect sense, but frustrating sometimes as it's just a lack of plastic in the rear hub design me thinks...
(I know, I know, my fault for crashing...)
Lonestar is offline
Old 05-22-2019, 02:31 AM
  #514
Lonestar's Avatar
Originally Posted by team green
I use a set screw also. But here’s the part your talking about.
https://www.apexrc.com/collections/x...ht-upper-block
Thanks both - that's the one
Lonestar is offline
Old 05-22-2019, 06:07 AM
  #515
silden's Avatar
Xray should revise the rear hub and remove the 2nd hole.
silden is offline
Old 05-23-2019, 07:38 AM
  #516
https://www.teamxray.com/xshop/products/proddesc.php?prod_id=3283&crt=c819904dde95535c6045 2b16c1c494f6&kategoria=4299&catName=Composite%20Up right%200%B0%20Outboard%20Toe%20-%20Hard%20-%201-Hole
Old 05-23-2019, 08:04 AM
  #517
silden's Avatar
This one has the hole right in the middle of the two original positions, therefore it changes the outer link position.
silden is offline
Old 05-23-2019, 03:15 PM
  #518
Yes, but at least you have a choice of using a one hole version. It might even work better for you, who knows???
Old 05-24-2019, 12:52 PM
  #519
fpart's Avatar
Trader Rating: 41 (100%+)
Anyone running the rear steer in black crc carpet with touring or usgt? I was wanting to try it but don't know where to start.
fpart is offline
Old 05-24-2019, 01:54 PM
  #520
theproffesor's Avatar
Trader Rating: 66 (100%+)
i ran it on both my USGT and VTA cars. Ended up keeping it the VTA, but ditching it for standard set up in GT. I needed more rear toe in gain, and stock setting is max gain. I tried to get the inner pins as straight as possible for my set up.
Most i I know that have tried it in TC and GT on black carpet end up going back to standard as well.
team green likes this.
theproffesor is offline
Old 05-26-2019, 02:26 PM
  #521
has anyone ran the aluminum hubs front or back? Are they stronger. How are they are black carpet?
ryan391 is offline
Old 05-27-2019, 05:28 PM
  #522
A friend is wanting me to help him mount a body on his 18 before a race this weekend. All I have is the 19. Are the “center” position on the front and rear body post the same as the body post on the 18?
Old 05-27-2019, 05:39 PM
  #523
silden's Avatar
I believe that it should fit.
silden is offline
Old 05-27-2019, 07:45 PM
  #524
I dont think so.
I have my front body mounts in the center and the rear mount set with no spacers to match my older bodies.
Old 06-03-2019, 06:21 AM
  #525
dvaid852456's Avatar
Does anyone have a link for a T4 compatibility chart. I swear I saw one posted on either the '17, '18 or '19 threads but cannot find it anywhere?
It showed the required parts to upgrade the various chassis and backward compatibility.
Also if fitting the SLP shock towers on the '19, is the only option to drill holes for the pins or grind off the pins?
dvaid852456 is offline
