UF1 is Back In SoCal! >
Like Tree311Likes
Old 01-10-2023 | 07:26 PM
  #481
MikeR's Avatar
Good stuff. It would be interesting to show the podium finishers tire compounds for each race too I think. Exotek yellow front with red rears for me.
MikeR is offline
Old 01-11-2023 | 04:12 PM
  #482
Lol. My race 12 finish was actually not a DNF (36/15:01.951). My car was agonizingly in limp mode for the entire run...but I did finish
GT CRUSING likes this.
Thad Garner is offline
Old 01-11-2023 | 04:33 PM
  #483
MikeR's Avatar
Looked like you were experimenting with TeamPowers tires for that run?
Thad Garner likes this.
MikeR is offline
Old 01-14-2023 | 12:45 AM
  #484
GT CRUSING's Avatar
Thad Garner Yes you are correct and I have corrected that DNFs results to 0. Wow, I totally forgot to check the 15minutes run...but yikes race 12s a throw out on the regular rc points.
MikeR I too would like to see a curiosity report for tire choices for All of the Amain drivers to be reported in tech after each Amain. But for the fastest lap I ran all red exoteks the entire event. Yes that gave me some wild oversteer which was especially hard to control in the last 5 minutes of each race. If you look closely at my aeropackage for Revelation I was running maximum rear downforce and lowest front downforce to combat the oversteer. Looking back, I did run the yellow fronts and red rears and I found that to be a great combo when the sun was out during practice sessions. But I was betting on cloud cover for the races, which turned out to be very dynamic and the weather was mostly 61F. I found all reds to work a charm at rev with temps from 50F to 65F with no sun and cloud cover.
However, If the raceday temps were 75F or higher with lots of sun, I would have definately run the Hudy/Gravity RC which are a much harder tire compound to the exoteks. It would be great if there was a harder rear compound for the exotek tires. In the weeks prior to the raceday, I trialled the Yellow Exotek and Red Exotek with temps higher than 75F and they simply did not work at Revelation.
MikeR and Thad Garner like this.
GT CRUSING is offline
Old 01-16-2023 | 12:46 PM
  #485
I really like F1 class very realistic scale!!
MVP22 is offline
Old 01-17-2023 | 03:47 PM
  #486
Volante white rears and blue fronts. Bit of a dice roll but didn't matter with my run being a bust dealing with the motor issue.
MikeR likes this.
Old 03-04-2023 | 08:12 PM
  #487
GT CRUSING's Avatar
Default Fantasy F1 Standings & Statistics
Quite the shake up in the fantasy F1 standings, Brian finally scoring that 1st win of the season and the championship lead with only 6 races to go
Entirely Unofficial RC points for the top 5, boy oh boy is it close with Lane and Enriquez tied for 3rd. Brian only has a 4 point lead and unlucky race 13 has cost Aaron dearly the lead of the series. Every point is going to count in the final 6 races
Old 04-23-2023 | 09:33 PM
  #488
GT CRUSING's Avatar
Default Championship Finale Fantasy Results
With the season wrapped up, Brian R wins the championship for both the real and rc points system...well the top 3 are the same too
-All of the top 10 in points have all of the podiums
-All of the top 5 in points have all of the wins
-Interesting note, everyone finished race 16
For laps completed only 7 out of 22 drivers attended every single race this season
Only Phillip and Thad had zero DNFs this season and are the top 2 in the total laps run this season
Alain Patry likes this.
Old 04-24-2023 | 06:04 AM
  #489
J.Gonzalez's Avatar
Originally Posted by TPhalen
Right out of the package, these tires are amaze-balls! I was running an older set of 71/72s and had good lap times - put these on and I dropped about 1/2 second per lap, easily. Like you, my fronts grained quick but didn't seem to loose and grip (I run a pretty aggressive steering setup). The rears look brand new still. I'll add that this is the first time I've ever felt SO confident in the car that it wasn't going to spin out. Ever.
I'm using the Trackstar Dream Clean cleaner right off the track, then the Gold sauce on all 4. I let it set for about 5 minutes then wipe off any excess. Seems to work well.
I haven't run the Exotek tires enough to see how long they last but I intend to.
Yup similiar finding but very impressed with grip of tires. I was initially concerned that front graining would mean tires would fall off after a run or two. But to my suprise yellow front and red rear worked great on cool cloudy day air temp about 60 on well cleaned but unprep track surface. Ran about 10 packs and laps times did not fall off.
I also tried to mix new red front and used red rear and car pushed like school bus. So it looks like new and old tires dont mix great. I borrowed a used set of red front from another racer to test with my used red rears and the car was very loose due to aggressive steering. This also lead me to believe the tires take some time to break in.
Great tire hopefully they will prove to have good durability and should be great tire for any club series.
J.Gonzalez is offline
Old 12-03-2023 | 10:49 PM
  #490
GT CRUSING's Avatar
Default UF1 23/24 Fantasy Standings
Here is the new seasons Fantasy UF1 Standings with only the Top 20 drivers plus anyone who scored points in the top 10 in any race.
Looks pretty tight in the midfield from 4th thru 13th
Seems like this years tittle fight is between Tony P, Ken G and Thad G
Old 06-02-2024 | 09:33 AM
  #491
jneezie3000's Avatar
Default Canadian Grand Prix
With, the Second UF1 race of the 2024 season approaching, who's ready to race Supertub? What chassis are you using?
https://www.uf1rcracing.com/home
jneezie3000 is offline
Old 06-02-2024 | 03:03 PM
  #492
MonkeyCmonkeyDo's Avatar
If uf1 makes it to nor cal or the great pnw lmk please. I'd like to race. So cal and longer racing traveling for me is still a cpl yrs or more out. This is invite only? I run x1 23' rouche evo3 and a trf102 I'm getting rdy for tcs. Ty!
d
MonkeyCmonkeyDo is offline
