Can-Am RC Series >
Can-Am RC Series
Like Tree1141Likes
Can-Am RC Series
    Hide Wikipost
Old 11-27-2018, 10:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Can-Am RC Series
Last edit by: Joe Kimble
Cheaters Suck.
MOTOR OF MONTH NO MORE!!!
3.5mm MALE bullet connectors are REQUIRED
at all CanAm races
CanAm Motor & Transmission Specs
USGT
ORCA------------4.40min FDR Indoors-------------169g
STOCK TC
TEAM POWERS------5.40 min FDR Indoors-----------------173g
SUPER STOCK TC
SCORPION-----6.20 min FDR Indoor--------------------170g
CanAm Stock 1/12th
TEAM SCREAM-------------OPEN-----------------------160g
CanAm Super Stock 1/12th
TEAM SCREAM-----------35T/88T-----------------------160g
CanAm F1
SCORPION-----------------28T/92T-----------------------170g
CanAm WGTR
ORCA---------------------36T/92T-----------------------169g
TC/USGT Likely Spur/Pinion Combinations
USGT
1.7 Internal
96/37 => 4.411 FDR
101/39 => 4.403 FDR
1.80 Internal
93/38 => 4.405 FDR
98/40 => 4.410 FDR
1.85 Internal
100/42 => 4.405 FDR
1.9 Internal
95/41 => 4.402 FDR
102/44 => 4.405 FDR
2.0 Internal
99/45 => 4.400 FDR
STOCK TC INDOOR
1.7 Internal
102/32 => 5.419 FDR
105/33 => 5.409 FDR
108/34 => 5.400 FDR
1.80 Internal
99/33 => 5.400FDR
102/34 => 5
.400 FDR
105/35 => 5
.400 FDR
108/36 => 5
.400 FDR
111/37 => 5
.400 FDR
1.85 Internal
108/37 => 5.400 FDR
111/38 => 5.404 FDR
114/39 => 5.408 FDR
1.9 Internal
108/38 => 5.400 FDR
111/39 => 5.408 FDR
2.0 Internal
92/34 => 5.412 FDR
100/37 => 5.405 FDR
108/40 => 5.400 FDR
SUPER STOCK TC INDOOR
1.7 Internal
106/29 => 6.214 FDR
110/30 => 6.233 FDR
1.80 Internal
100/29 => 6.207 FDR
107/31 => 6.213 FDR
114/33 => 6.218 FDR
1.85 Internal
104/31 => 6.206 FDR
114/34 => 6.203 FDR
1.9 Internal
98/30 => 6.207 FDR
108/33 => 6.218 FDR
111/34 => 6.203 FDR
2.0 Internal
112/36 => 6.222 FDR
NB: Serpent Project 4X was checked and due to the O.D. of the center pulley the internal is not exactly 2.000. Testing revealed it is closer to 2.005. For Serpent Cars ONLY, the drivers who wish to be as close as possible to the Minimum FDR can use the following spur/pinion combinations: SS TC => 99/32; Stock TC => 97/36; USGT => 101/46.
Print Wikipost
Old 10-16-2018, 10:31 AM
  #556
Joe Kimble's Avatar
Trader Rating: 19 (100%+)
Originally Posted by KUI
We also tried this with 104/34 64 pitch. Same result.
EA's checker read 6.17. That's when I went to 84/27 and it read 6.22. Sorry I'm not one to use fluffy words.....
no worries.
ok so you did try with 64 pitch. Thanks for the input. I will do some testing and see what's up with the other combinations. Which car was this testing done with? 4X?
Joe Kimble is offline
  #557
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Joe Kimble
Not about being sensitive. He called BS on something he hadn't verified. Not a big deal, just needed to be addressed. Let's move on.
no he did verify ... and had eric anderson and i confirm his findings .
he was calling bs on the 2.02... internal drive speculation
jlfx car audio is offline
Old 10-16-2018, 10:35 AM
  #558
Joe Kimble's Avatar
no worries.
ok so you did try with 64 pitch. Thanks for the input. 6.17 still higher than what it should show at 2.0 (6.11). Somehow the other 2.0 cars and 1.9 cars are spot on with the checker. I will do some testing and see what's up with the other combinations. Which car was this testing done with? 4X?
Old 10-16-2018, 10:40 AM
  #559
KUI
no worries.
Yes 4x, but the s411 runs the same internal pulleys.
KUI is offline
Old 10-16-2018, 11:45 AM
  #560
Joe Kimble's Avatar
got it thanks. I will update everyone once I have tested more stuff..
Was the the FDR checked on the spool side, rear end on diff, both?
Old 10-16-2018, 11:59 AM
  #561
Team EAM
Trader Rating: 79 (100%+)
Spool. Cant check it on the diff side as it will give false readings.
EAMotorsports is offline
Old 10-16-2018, 12:02 PM
  #562
Trader Rating: 177 (100%+)
Do you not worry about the racers running a diff front and rear? Or how would theyre FDR be checked?
thecaptain is offline
Old 10-16-2018, 12:09 PM
  #563
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Anyone failing a meeter test would have a tooth + pulley disassemble/count
Honestly, this is likely WAY less of a problem than the internet is making it
hanulec is offline
Old 10-16-2018, 12:14 PM
  #564
I was just curious I do not run one front and rear, just popped into my head so I asked. I've only heard of positive things from people who have attended, im looking forward to trying it out this weekend.
NutDriver likes this.
Old 10-16-2018, 12:20 PM
  #565
no worries.
i think this is more of a question for the serpent thread not the canam thread . as to the canam formula is working great for every car but something about the maunfacturing of the serpent car is giving unexpected results ...
so yea cant wait for the canam races !
Old 10-16-2018, 12:21 PM
  #566
Team EAM
If youre running a diff in the front then it will have such heavy fluid in it that it will act like a spool when checking with the FDR meter. On a lighter fluid rear diff its possible it could slip some and alter the readings.
EA
thecaptain likes this.
Old 10-16-2018, 12:28 PM
  #567
Joe Kimble's Avatar
EA
100%
Agreed... Just trying to figure things out and do it the right way.
If I posted misleading things then I apologize. I did say though that nothing was definitive and that I'd have to do more testing.
Old 10-19-2018, 11:54 AM
  #568
Have 19 Stock TC motors on the way for Soda City RC!
iTz Nicholas72 is offline
Old 10-26-2018, 08:34 AM
  #569
Old 10-29-2018, 07:11 AM
  #570
Trader Rating: 88 (100%+)
One question I do have is that what were to happen if someone were to strip out the threads for the motor screws? Yes you can turn it for the other holes, but then the motor tabs will either hit the pod plate on a pan car or if you were turn them the other way now your wires are too short. And with the anti-tampering goo on the endbell screws you can't undo the motor and turn the case to the next set of holes.....
MUDVAYNE is offline
