BSR M RAGE UPGRADE DIFF GEARS >
Old 11-28-2017, 02:56 AM
Default BSR M RAGE UPGRADE DIFF GEARS
Hi Guys,
I have just purchased the BSR M Rage from Hobbyking and after some reading it seems that the diff gears are susceptible to being stripped out
I have heard some people upgrading these to metal gears (along with the outdrives) but i am struggling to find where to buy these stronger gears from?
Can someone please help me find the link to buy the upgraded metal diff gears from?
Thanks in advance
Jayden
EGG ROLL is offline
Old 11-28-2017, 05:51 AM
gigaplex's Avatar
Originally Posted by EGG ROLL View Post
Hi Guys,
Thanks in advance
Jayden
There's already an M.Rage thread where this has been discussed. The small input gears are available in metal, from Hobbyking. You'll need a short input shaft (available from Hobbyking) and a short spur hub (not available from Hobbyking, should be available from https://m-racing.co.uk/). It's apparently possible to shorten the stock spur hub in a pinch. The metal outdrives are also available from https://m-racing.co.uk/, or from NitroRCX under the Drift King branding (part number MAD-NH3119).
I've heard rumours of large metal diff gears but the OEM doesn't make them and I don't know where to get them from. These don't strip as often as the smaller gears though, you probably don't need them.
gigaplex is offline
Old 11-28-2017, 11:36 AM
RotorTruck's Avatar
OK, a few months ago I ordered two plastic ball diffs from Hobbyking, and they shipped me two gear diffs with metal ring gears and metal outdrives. Go figure, I sh!t you not.
You need the shorty metal input gear and shorty metal input shaft like mentioned.
I have ripped the stock plastic ring gear along the holes for the balls. All the way around. With a 13.5 on blinky and sweep slicks, sticky track. Never ever damaged any plastic teeth.
Never had a driveline prob with 21.5 nor 17.5, other than me over tightening the ball diff. But the plastic outdrives do wear where the pins make contact.
RotorTruck is offline
Old 11-28-2017, 12:57 PM
gigaplex's Avatar
Seriously? I asked them if they could source the gear diffs and they said no.
gigaplex is offline
Old 11-28-2017, 03:40 PM
RotorTruck's Avatar
Totally serious. Picture for the part was the good old plastic ball diff. I could say order it and see what ya get, but wouldn't want my name on a game of chance.
Old 02-13-2018, 03:29 PM
gigaplex's Avatar
I finally decided to take the gamble.
It paid off
gigaplex is offline
Old 02-14-2018, 01:25 PM
Can you give me reference or link on website to order this parts please?
calimerosf501 is offline
