wheel alignment - need help! >
Like Tree4Likes
Old 11-24-2017 | 12:26 PM
  #16
1spunspur's Avatar
Originally Posted by Bob Corey
This is the servo-saver slop and it's the whole play there is in the steering system, is it much? (If I hold the servo saver blocked there's no play)
BUT , even with the servo locked down with a hard wire on the chassis so it can't move and the servo off the power, I still had the random steerings!!!
https://www.mediafire.com/file/pq23b...ver%20slop.mp4
Hi Bob, I had a similar problem. Turned out to be a transmitter problem. Probably got damaged in the mail. Don't get me wrong, I'm no expert it took me a long time to find the problem. I cleaned the gravel from underneath the servo saver , replaced the servo , and finally got a new transmitter. Problem solved.
1spunspur is offline
Old 11-24-2017 | 12:36 PM
  #17
1spunspur's Avatar
Sorry Bob, I could not see the videos. I'm having problems with my computer. Hopefully my advise will be helpfull.
Old 11-24-2017 | 02:23 PM
  #18
gigaplex's Avatar
If it's happening when the servo isn't powered then it can't be a transmitter issue.
Bob Corey likes this.
gigaplex is offline
Old 11-24-2017 | 03:19 PM
  #19
Bob Corey's Avatar
So after some testing , walking next to the car while going straight I noticed the car goes a lot like a boat almost all the time while sometimes it kept following a turning course while none of the wheels were moving left or right, mainly the back side of it...
So I think the 80% of my problem is because of this:
*let me wear my glasses*
The back tires have the inward toe so each wheel pushes to the center, so the back side in order to stay centered, drifts all the time like a boat. Now, when a wheel grabs better for some reason, forces the car to take that direction leaving the other back tire drifting because on such a light weight car is easy to drift. See the picture below. Kg = weight = better grip.
Now what confuses me is that almost all RC cars I've seen have the inward toe on the back wheels, so why isn't everybody having this problem? Is it because of the flat tires I am on? Should I 3D print the back suspension arms so the wheels don't have inward toe....?
Bob Corey is offline
Old 11-24-2017 | 05:21 PM
  #20
Bob Corey's Avatar
Yep , I just proved my theory right!!! After a very long time I finally did a test half-removing the chassis shafts of the rear suspension arms, straighten up the rear toe by putting some spacers between the arms and chassis , I did some tests and YES it's fixed!
(this is just temporary you can't run it like this for a long, the suspensions hardly work and did it just for the shake of the test)
Now the problem is that I don't know where to find adjustable rear suspension arms, or the STL file to 3D print a pair that has less inward toe! Can you help???
Before and after
Close up of the temporary mod
Old 11-24-2017 | 06:55 PM
  #21
gigaplex's Avatar
That's just a band aid. The car won't handle properly at speed without some rear toe and any car with a couple of degrees rear toe should track straight. There's something else going on here.
Also, most common 3D printing materials aren't suitable for suspension parts. Too fragile or flexible.
gigaplex is offline
Old 11-24-2017 | 08:24 PM
  #22
Bud
http://users.telenet.be/elvo/1/1_content.html There's a little go tab to the right. kinda hard to see.
Bud is offline
Old 11-25-2017 | 01:15 AM
  #23
Roelof's Avatar
For HPI Sprint 2 - Yeahracing - Yeah Racing Aluminum Rear Hub/Knuckle Arm Toe-In 3 Degree For HPI Sprint 2 #SPT2
Roelof is offline
Old 11-25-2017 | 02:01 AM
  #24
snuvet75's Avatar
You keep saying the car runs like a boat. Basically you r saying one of the rear tires is not turning but sliding on the ground right? That is not because of toe. Something is binding.3 degree angle never makes tires slide instead of turning unless u have drift tires or running on very low traction surface.
snuvet75 is offline
Old 11-25-2017 | 04:30 AM
  #25
jgraham37128's Avatar
That is fine, but move them all the way back and forth and look for something else moving. The play in the linkage isn’t what’s causing it to wander left and right down the straight. Either something is loose or the Servo is bad. That’s the only two things it can be.
jgraham37128 is offline
Old 11-25-2017 | 06:54 AM
  #26
Bob Corey's Avatar
3 degrees is the stock too...
Old 11-25-2017 | 07:08 AM
  #27
Three degrees of rear toe-in is standard and helps keep your car going straight. Reducing it or eliminating it altogether will make your car harder to drive. I recommend you go through the rear suspension as follows;
1) Remove the rear tires and rear shocks.
2) Move the rear suspension arms up and let them drop on their own. They should drop all the way down without you touching them. If not then there is binding somewhere. Fix as necessary.
3) Ensure the rear inner hinge pins are perfectly flat and not bent. If bent, replace. You will need to disassemble to check this.
4) Ensure the outer hinge pins are also flat and not bent. Replace as necessary
5) Make sure the rear droop is the same left to right. Adjust until they are and use the setting from your manual.
6) Check the rear shocks and look for a bent shaft. If straight, ensure they compress and expand without sticking. Fix as necessary.
If all checks out, then do the same to the front suspension. Fix or adjust as necessary.
The tiny bit of slop shown in your video is normal and should not affect the way your car tracks much if at all. Shimming to the point of zero movement might make things too tight and make it worse.
SteveM is offline
Old 11-25-2017 | 07:39 AM
  #28
Bob Corey's Avatar
Thank you for the detailed message, but the car is pretty much new, the suspension arms move perfectly and when you lift the car a little the wheels have the same distance from the ground. It seems really weird to me that the angle helps the car go straight because
a) IMAGINE the toe was 20 degrees in, then the wheels would be drifting towards each other even more making the car's tail drift left and right.
b) because I did a test with almost no inward toe and my flat tires were cooperating nice with the ground making it drive straight with no weird and unpredictable movement.
I am really confused :-s
Old 11-25-2017 | 09:17 AM
  #29
Airwave's Avatar
You have to understand that EVERYBODY is running toe in the rear. That's a way to compensate the fact the front is too efficient compared to the rear.
Now, the toe must be symmetric. There is no way that it will make the car drift the way you are describing it. Please read the definition of toe and how it works (mainly by getting rear tyres hot).
On drift car, people are reducing the rear toe to obtain a more stable drift. In this case it is preferable to have outboad toe instead of inboard toe.
Airwave is offline
Old 11-25-2017 | 10:03 AM
  #30
Before and after
If you're able to change toe like this, there's something wrong with suspension arm mount. It shouldn't let you change toe like that. Maybe it's too soft to hold constant angle, that's why is your car unpredictable.Look forcaluminium mount, which could solve it.
As everybody here already said, reducing toe won't help. 0° toe-in makes rear end unpredictable at high speed, especially while braking.
Papi is offline
