Ball Diff vs Gear Diff
#181
I can't answer that question, because I don't own any 1/10 racing buggies with the option to use a center diff. I can tell you that I've noticed significantly better cornering-while-accelerating with a center diff in all of the RCs I own that can use center diffs. There's a lot less tire scrub and the steering is less prone to sudden oversteer.
Believe what you want. You won't convince anyone and they won't convince you. That much is obvious at this point.
You don't care about lap times so whatever you perceive is all that matters for you. Most people on this forum race, so how the car handles when you are trying to drive it as quickly as possible matters to them.
#183
#184
I still think this idea is worth a punt, especially the second pic with more planet gears to distribute the load. Definitely not the one off the 3000gt vr4 though, anything with a viscous coupling is far too complex for rc.....
Your idea of underdriving would sort of work as well, but the center diff would be working overtime, causing it to overheat and degrade the fluids rapidly. You may have to up the oil wt.
#185
That is how the RC-Monster.com "Slipperential" works -- or worked. It was a fearsomely complex piece of kit to assemble just-right, and it apparently didn't sell well enough to justify continuing to manufacture it after the initial production run. Slippers and diffs are just too complicated to assemble into a single unit, and it's more practical to have them as separate transmission stages, when space allows.
#186
I'm quite certain that a spur can be attached to a diff case, sandwiching a pair of slipper pads/thrust rings using an appropriately sized ring nut for torque adjustment. This wouldn't nesscessitate a new diff design as such - the diff could still be an open gear diff or Torsen - just the way the spur mates to the diff case. The ring nut would allow the out drive to pass through it. Bosh. One centre diff with a slipper on it.
#187
But certainly not impossible!
#188
Yes, I was suggesting something similar, but what would the slipper nut thread on to? The outdrive itself? It would need to be seriously lengthened and require a thrust bearing to stop it screwing/unscrewing itself. See ball diff for details. Or a projection from the case itself which is threaded? You're still going to require a lengthened outdrive, as it needs to accommodate the length of the slipper assembly. Possibly a third bearing in the middle to support this beastly creation where said lengthened outdrive exits the diff....
There's a lot of people out there that love electric model racing cars. Having a slipper on a centre diff is merely an engineering problem awaiting a design solution.
#189
^You know, I've been thinking of making a torsen diff for R/C. Problem is, I don't have the time, money or machine resources for it. Strangely, I believe small enough worms can be purchased off the shelf.....
#190
#191
Cutting worms and worm wheels, especially at our scale, requires specialized machinery and tooling. Also it requires very hard steels(high tooling wear) or a subsequent hardening process(industrial ovens).
#192
Jammin sold an upgrade diff too -
This type of design could be scaled down from 1/8th to 1/10th scale and used on the front diff of 1/10th 4WD buggies. If a slipper could be mated to one, then a centre Torsen could become a reality for 1/10th scale also. Due to the way Torsens don't diff out like open diffs, they would be far too punishing to the rest of the drive line without the slipper.
#193
I believe the Jammin one is very similar to/the same as the Hobao one, seeing as they were both distributed under OFNA. You are right about Torsens being potentially brutal on the drivetrain, unless you go all hardened steel drivetrain and gear diffs. Which makes things very noisy.
In theory, if you got the helix angles right, you would have virtually limitless grip, atleast in stock buggy (13.5/17.5). Cornering speeds would become almost completely dependant on anti-roll bars/anti-squat/anti-dive.
Contacting fioroni might be a way, but as I said earlier, I don't have the resources. When I finally do, it'll probably 3d printed (as a proof of concept/prototype).
#194
Question. Discounting my theory that there is an increase in friction between the balls and gear cage when under power in a ball diff, if the gear is under load, and is trying to skid the balls on the rings, then would that force increase the tendancy of the diff action to get heavier? I don't mean when one wheel is in the air. When there is some traction on both rear wheels and a load on the diff gear. I'm not saying that theory is true. Just was thinking about it and wanted some feedback.
#195
If the load increases past the point where the balls are able to roll between the diff rings and start to skid/slip, the ball diff is no longer acting as a differential. The more it skids, the less it acts like a diff.
Imagine your tyres aren't glued onto the rims. If the wheels are spinning inside of them, your tyres aren't acting much like tyres any more. It's just the same with your diff. If your diff slips, it's rebuild time.
