TLR 22 4.0
#2431
#2432
Is there a rear hex with about 7mm thickness available for the 22 4.0? Maybe from the 22-4, SCT or Stadium Truck?
#2433
This weekend I was doing some testing on our Astroturf track. I did put the TLR234007 spindles on and they were great,really smooth steering feel. Unfortunately I broke one and had no more left, they are no more available over here in Germany. So I put the 4.0 spindles on with Ackermann #2 and the car was much more aggressiv. I raised the front axle 2mm and went for a stiffer front spring (Yokomo RP purple instead of black) and it was better,but I found out that the steering arm hits the front arm under compression. I tried Ackermann #3 and the car was really good, with a good amount of grip but less aggressiv and twitchy.
#2435
Just saw that FB post, is TLR possibly announcing a new buggy on Thursday???
#2438
Frank. On the facebook post today you have a pic of your car with alum rear plus 3 hubs on it. The ledt is in right aide and vice versa. Is there something special about them being on backwards?
#2440
Hey Frank.
Any Setups, Input, Tipps and Tricks from your carpet testing with Dakotah?
#2441
2.0 Steering Spindles
Tried the 2.0 Steering spindles on grass today, was only practicing (with out timing) but didn't feel much different from my current set up of the 3mm stock 4.0 spindles.
Will try them again on astro next time I'm at an astro track but for grass I prefer the option of moving the hubs forwards and backwards.
LRC (clay laydown setup) worked much nicer on the grass compared to the HRC - much easier to drive and less edgy.
#2442
Tlr alum steering bellcrank and draglink. Are you also flipping this when running on carpet. Or do you not run the alum bellcrank on carpet and turf?
#2444
Frank. I tried the alum flipped bellcrank got bulkhead all dremeled to clear but i cant get full throw right with it. Im maxed at 150 on radio. I pit flipped plastic rack back in and im at 125 left 130 right full throw. Am i missing something? Can you post a pic of your alum rack setup including where servo is mounted? Dorward or back
thank you
thank you
#2445
thank you
thank you
