Tekno RC EB410 Thread
#4532
If you need better bump handling but can't go lighter on the oil then going up on the hole sizes should be fine. I would start by doing only 2 or 4 of the holes drilled out to 1.2 and keep the oil the same at first. I'm guessing if you go to 4x1.2 + 4x1.1 you'll end up at 50-100cst heavier to get the same static feel.
#4534
I'm starting to put a bit of pressure on them Pro's.
#4535
Tech Legend
Good outing by the EB410 here for mod. Ended up taking the win after fighting my way back from couple of back pile ups.
Really liking this astro setup that is common out there with a few changes for a bit more rotation. (less rear toe mainly).
Also my EB210 conversion has been doing great since I got it. Heck of a vehicle on the higher grip stuff we run on these days. Nice to also share parts with my EB410 too
#4536
So the eb210 and et210 conversions compete with legit 2wd's?? I love the design of the eb410/et410 so much id like to stay with tekno for those classes too..
#4537
Tech Legend
I am at about 1560grms or so with the stock chassis and common lightening items. Some of the newer changes to the conversion I think will bring down the weight a bit too.
Its driving feel reminds me of the Durango DEX210F and seeing comments people make about the kyosho RZ6, its probably similar to that as well.
The other vehicles at our track cover a variety of vehicles from the Associate B6.1, Yokomo YZ2, and even the schumacher latest 2wd buggy (forget its name).
The funny thing is the creator of the vehicle mainly uses it on loose tracks, something you wouldn't figure. For me as we changed over to astro, few changes to his recommended setups and its been great.
All in all I wouldn't mind tekno running with this platform a bit as a basis for other vehicle designs that cover more traditional classes, especially as the traction levels in general for RC have grown a lot.
#4540
*** Getting an error when trying to update the Wiki to add this link to the list of upgrade options:
Red RC ? RC Car News » T-Works EB410 titanium king pin screws
T-Works have introduced a 4-piece set of titanium king pink screws for the Tekno EB410 buggy. The fasteners are made of high-quality 64 grade material for a low weight and exceptional corrosion resistance. Using the king pins in place of the original parts will reduce unsprung mass for increased suspension efficiency and an overall lower weight.
#4541
ran a few practice packs on Friday at LSR then ran Delta’s spec shootout today. Had some rough qualifying. I would be P5 for the A-main. After the 7min main was over I would take home the win the first time out with the kit setup with one change. This buggy turned a lot of heads today. Did I mention how easy this buggy is to drive
#4542
ran a few practice packs on Friday at LSR then ran Delta’s spec shootout today. Had some rough qualifying some I would be P5 for the A-main. After the 7min main was over I would take home the win the firat time out with the kit setup with one change. This buggy turned a lot of heads today. Did I smention how easy this buggy is to drive 😜😗
#4545
Tech Legend
yeah its worth a look. I swap cars alot, just how I am, one of my favorites is the Yokomo YZ2 line up, I felt I got the quality of parts with the reasonable pricing at the time versus say an Xray (quality, big $$$) versus the AE I had (okay quality, cheaper $$$).
after running the Tekno EB210 conversion for awhile now, I sold pretty much all my yokomos (last one here is my personal car, held on to for a buddy).
I haven't found the urge to swap
