Tekno RC EB410 Thread
#3961
That top hole of the exotek hubs combined with the diff shims will make it so the dog bones won't have enough engagement while in full droop.
I was able to make these HB rear axle rebuild kit longer dog bones resolve the issue. You have to do some minor filing so they fit the outdrives properly but its minimal.
#3962
#3963
I'm currently not running that forward shock setup I wasn't happy how the dog bones align with the outdrives it didn't insert far enough in so I managed to break to outdrives in the process I put all the shims in the rear of the arms to try to push everything forward to correct the angle but still it's not good enough
#3965
I don't race (yet) but I enjoy being fast and in control on the track!
#3966
You are right it didn't prove to be necessary on my clay track. I have just been playing around with extremes setup changes so I can identify the changes better. I don't feel I tend to pick up on the subtle differences so when I do extreme changes I can tell right away what the affect may be then tone it down till I like it.
#3967
#3969
That's what I did . I thought it would help the geometry when using the diff risers
#3971
Same here as far as using someone elses setup. I usually start with the kit setup and work from them or in my current case, I went with the recommended 13.5 setup and made my own changes where I felt I needed it. Like I run no front sway bar and my ride height is different than what the setup asks for. Mostly just the shocks and diffs are the same as the recommended setup lol
#3973
#3974
