Tekno RC EB410 Thread
#198
I see what you did there.
#201
You won't need a lot of wire is all I can say.
About wire gauge, I pretty much stick to 12 gauge for everything. I can see using 14 on maybe a 2wd buggy where you're usually not running as fast of a motor and you want to save weight since the wires can be longer.
#205
Already know what equipment I'll be using. All that's left to add in my cart is a pinion gear and of course the kit. All electronics will be new.
#206
Tech Legend
to be fair on other vehicles you do have the option to put your ESC and motor in different locations, so you could potentially not need much wire (on my dex410v5 I ran the ESC behind the motor in a back position and the shorty is on the other side, not much wire needed there at all, same with the D413 as far as pics I have seen). So I am curious if this means a radical change from what others or doing, or, they just went with locations that others also offer but optimized around that.
Should be good times for sure though to see Tekno's spin on a 1/10 4wd buggy.
#207
in addition to having several different motor/battery layout options, one of the really cool features that I liked with my ER-14 was the ability to use their slide lock to tune the center diff without having to re-adjust the mesh with the pinion... hopefully Tekno has adopted the best features of all brands into the ultimate wheeler
#208
Tech Legend
another feature that was similar but I liked was that on the DEX410v5, there motor cam has these "ticks" (little white lines) on it along with the motor mount, each tick would represent a position where you get optimal mesh. So you just line up the ticks on the mount and the ticks on the cam and have proper mesh. I really liked that feature.
#209
#210
http://site.petitrc.com/setup/intech...R14_Manual.pdf
I think the only limiting factor with shaft drives are the ability to run a transverse shorty layout, the only one I've seen do this is the BZ-444 and it would do better with sub-shorties because some brands of shorties were too tall and would rub on the center shaft
