Tekno RC EB410 Thread
#1681
Are the Lunsford turnbuckles different lengths than the the stock turnbuckles as their listed lengths are shorter than the stock parts dimensions. Or is it that they are the the same length, but just have different dimensions listed compared to the stock dimensions listed?
#1682
Alright... So, which brand of drill bits fits best? I have some AE drill bits, and they are a little on the "too big" side.. I almost have to snap the screw/set screw onto it..
Not to mention, the 1.5 screws in the diffs worry me.. I'd hate to strip one of those out in between quals.. I know that size/space is a factor, but would there be any possibility of 2.0 screws for the diffs???
#1683
For full adjust ability, your probably going to want shorter links if doing the change.
#1684
#1685
Hey guys, I've updated the Wiki post at the top of the page with more information that has been published. We seem to be getting a ton of the same questions over and over, so let's try to direct people to the wiki. It has the answers. If it doesn't, then let's get them there!
#1686
I ended up getting 42mm front turnbuckles (40mm were out of stock) and they fit. Now I don't know how much adjustment I am going to have. Time will tell, but I was able to get kit setup on the car. They did offer a slightly smaller size, which I may get just to avoid any issues.
#1688
#1690
Servo horn......
Literally thats it. I have seen one broken diff case but that is the only other item i have heard of breaking.
#1691
Just listing the items I've seen here and on social media as having been broken:
Front diff case
Bent hinge pins
Shock cap (possibly cross threaded at first)
Stock servo horn
Hinge pin inserts
Most of those have been unique cases with no solid trends. Unlike the B64 thread where every 5th post for a while was a broken diff case or steering rack.
Front diff case
Bent hinge pins
Stock servo horn
Hinge pin inserts
#1693
Front diff case
Bent hinge pins
Stock servo horn
Hinge pin inserts
Front diff case
Bent hinge pins
Stock servo horn
Hinge pin inserts
#1695
I got a chance to build one this past weekend and ran it this evening on a dirt track using Hole shots. Totally box stock oils, springs and set up. I was impressed how well the rear stayed planted through the sitchback section and powering out of 180 degree corners, some of which are off camber and even a little up hill. No issue laying down the power onto the straight either, I tried to get the rear end to break loose but she kept tracking straight. It was a bit damp this evening so traction was high for out door dirt but I came away impressed. I'd liked to have tried some weight in the back to see how it would change the feel but it didn't seem to need it. It jumped well, no crazy nose diving or anything weird. I really liked the big shocks too. Nice kit.
Thank you, Finally a drive report worth reading.
Do you think lighter springs and shock oils would have made it even better?
