Tekno RC EB410 Thread
#1637
#1638
Thanks. I built the car bone stock with kit setup, no changes at all except mounting the fan on top of the motor and an aluminum servo arm. My 22 4 and XB4 2017 are dialed and hooked up so i'm going to be spending all day with EB410 and see how it does. Temps here right now are hot and dry so the track should be medium grip with some high grip spots. Ive seen a few reports on loose and bumpy tracks but nothing on hard pack clay yet...so well see what happens. I have high hopes car is killer
#1643
Setup sheets are now available on our site. http://www.teknorc.com/setup-sheets/
In your set up, you had the rear tranny raised 2 mm. Did you you use the stock camber mount with 1 mm under the stud? Did you also use the stock C and D hinge pin mounts?
The manual said to use the option parts when raising the tranny by 2 mm including the 2 mm tower?
Not the Las Vegas setup
#1644
I got 5 packs in on Saturday at OCRC. I was on new Positrons up front so that was part of the problem because I had a pretty bad push with the stock setup save orange front springs. Next time I'm trying thinner front and rear and thicker rear.
