Team Associated RC10B64 Thread
#1277
#1279
Me? I only noticed a couple of screw lengths being off and I used the addendum sheet for the turnbuckle lengths. The rear sway bar links had to be lengthened a few turns as well. The most tedious part for me was making sure the diffs were shimmed properly...and even that wasn't bad. Car went together great.
#1281
Half way through my build and everything has been smooth with one exception. The front kickup on the chassis wasn't bent enough and the top deck was almost 2mm off when trying to screw it down on the steering posts. It flexed enough to go on, but I'll be replacing it soon so the entire front clip isn't under tension like that.
#1283
#1284
Pretty much the only annoyance I experienced as well... not a huge problem.. but it seems like there are multiple molds for the gearboxes and a little "Old School" massaging with a cartridge roll made everything fit much better.... after 5~6 times taking it apart and putting it back together...
#1287
Almost done with mine, only issue so far is the rear diff ring gear binding on the pinion, but only in 1 spot along the rotation. Tried all different combos of shimming and diff case tightening. AE is going to send me a new gear case to try.
Any thoughts on other things I could try?
#1288
#1289
#1290
I'm followed this thread since day1 and it seems like there are more people experiencing problems with the car than are actually praising it.
Anyone who has hit a race with the car have anything to say? Experiences? Comparisons?
I read one person compare it to his b44.3 and say (something like) 'it's gonna be good when I get the setup down'
