Team Associated RC10B64 Thread
#2971
That’s what i assumed as I was able to secure the front one but the rear seems impossible. I have been running the car without it, just making sure the battery atrap is well tightened and I’ve yet to have any issues with a pack moving around but I’d still like to get it figured out.
#2972
#2978
Team Associated B6 & B6D - Arm Mount Pill Chart
Front kick up is 10deg and centre - centre inserts are parallel hinge pins, easy to work the rest out
#2979
#2982
Nope....All that is exactly the same from the 64 to the 64D. Slipper vs gear diff is the main difference. 64 also has different sway bars, 7 deg front caster blocks (D has 10), 5mm front hexes. Everything else is minor, setup related items (springs).
#2984
If I'm not a pro, I only drive because it's fun, will I be slower on carpet with a B64d with the gear diff than I would be with a B64 with the slipper diff?
#2985
Using the same oil in the centre diiff on indoor carpet as you would slippy dirt and you will have the front wheels spinning like mad. Corner exit would be slow.
Increase the oil enough so that it doesnt spin the front wheels, and you will have no give in the drive train for on power downsides of jumps and you risk mashing the gears/spur.
You could however drive just fine by taking it easy but its a compromise and compromises are slower.
Saying all this, I purchased the “d” because it was much cheaper and bought a slipper as well. Best of both worlds.
710Likes
