TLR SCTE 3.0 Thread
#272
#273
#274
I wonder if the 3.0 braces and battery mounts are required when putting a 3.0 chassis on a 2.0? I wouldn't think so?
#275
Has anyone had a loose wheel hex issue yet? Mine slide right off the pin
#276
Any race updates? I finished my truck at the track. The first time I ran the truck was in the first qualifier.
I ended up qualifying 5th in the B main. Finished 2nd in the B and advanced to the A main. Where I finished 5th.
All with the kit set up🤗
#277
Like Casper said. It fits one hole in 2.0 chassis already. You would need to drill the second screw for the brace to work correctly and be strong.
You can get most of the benefits of the 3.0 by updating to the -3 chassis offered for the 2.0. Use TLR331015 -3mm Chassis. Bolts on and all 2.0 stuff fits. Rear center driveshaft might be too long. Just change the rear drive cup on the center diff to a drive cup that fits the diff out drives. That's the safe bet if your not ready for the new 3.0 truck for whatever reason.
#280
Ah, now I see the issue would be 3.0 chassis is wider, therefore the mudguard won't hold the outside of the battery like on the 2.0. I have different battery holders that should work though.
#282
i just started building mine last night. have not read any anything about
the diff screws that hold the diff's together, the 2.0 one's would strip
just by looking at them. these 3.0 diff screws seem to be stronger.
hahaha I even rounded off a brand new hex driver and screw head was fine!
#284
Will there be a Tuning Guide? Like the 2.0 and 22SCT has.
