TLR 22-4 2.0 Race Kit Thread! >
Like Tree243Likes
    Hide Wikipost
Old 06-20-2016, 06:37 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22-4 2.0 Race Kit Thread!
Last edit by: Kraig
Here are some good build tips and notes from b1narych0ice (thank you):
Specific build step comments/warnings, including areas I replaced stock parts -- Think of this as a FAQ that answers questions I had from other builders about each step:
A-3: You can instead use TLR Aluminum Servo Mount here.
A-5: Be sure to get the shorter screw in the correct hole.
A-6: Use a 76 or 78T spur if you are running a 13.5T-21.5T motor instead of the 84 in the kit! and...
A-6: The plastic washer between the pulley and the thrust assembly should be oriented so that the flat side goes toward the pulley, and the side with the ring goes towards the thrust assembly's metal washer. Diagram in instructions is correct, you just can't see that this washer isn't flat on both sides from the illustration.
A-7: Be sure the nut holding the Full-Time 4WD assembly is nice and tight, I have seen it get loose in the 1.0 car!
A-9: Put the gears on the jackshaft before the c-clips, so that you don't have to deal with getting the c-clips off to put the gears on
B-2: It seems to be possible to push the outdrives on so tight that they bind when spun, be sure to ensure that they spin freely as the manual notes.
B-7: You're screwing the 1.3mm screws into metal, don't crank so hard you strip the heads on the screws. While this is metal-on-metal, the manual doesn't call for loctite here.
B-8: The rear diff has fewer/bigger teeth, the front diff has more/smaller teeth.
C-3/C-4: TLR Aluminum Bellcranks and Exotek steering rack can be used here to increase durability/reduce steering slop
C-8: TLR Aluminum A/B Horn can be used to increase durability/reduce steering slop.
D-2: Don't worry about the kingpins sticking out the front even when the nut is tight, the bumper will push them in and keep them there.
D-5: Shock tower screws were the tightest plastic part on my kit, look from the side when tightening down the tower at the gap between the tower and the front bulkhead, tighten until this gap is closed.
D-6/D-7: Don't mix up the CVA pins and the hex pins, should be easy because hex pins are black and CVA pins are silver.
D-8/D-9: Use a toothpick to get threadlock in the metal block instead of applying it to the shoulder bolt, so that you don't get it between the plastic spindle and the metal block.
E-1/E-2: Don't mix up the 10mm pins for the rear hexes with the 11mm pins for the rear CVAs! They are packaged together and both silver, so it's easy to think you just have 4 pins that are the same!
G-1: No need to install the post on the right side if you are running a shorty and use velcro to attach the body to the mud guards. You can move the right post up or down a little so that it snugly fits your shorty battery.
G-2: Aluminum Servo Horn can be used here.
G-4: Adjust the length of the link and the servo horn position so that both the servo horn and the horn on the bellcranks are parallel with each other, and perpendicular with the link.
Hope this helps some of you that are putting your kits together, and thanks to Frank and the TLR crew for a solid kit!
Driveshaft Update from Frank - I've reviewed some parts today from stock. The 'issue' part is definitely the rear CVA driveshaft bone. The pin slot is not 90* to the bore for the barrel. We are working to get good parts made and here for CS use ASAP.
Some of the parts I checked were not 100% free, but definitely run-able. Keep in mind that the driveshafts should wear in fairly well, and quickly (within a few packs). If you have a 22-4 2.0 and are experiencing issues with the driveshafts, we won't have good replacements for probably a couple of weeks (no definitive timeline yet), so I would recommend running them on track for 1-2 packs, then rechecking. I think most will free up well.
I am sorry that we are having an issue. Everything was great during samples until production, but we'll make sure to get it right, and make it right for those with the bad parts.
What is the proper level for the diffs...i am used to building 8th scale diffs, i would assume its the same?
Just under level. You need some room for the output gear that is in the cap.
Frank can u explain what is the difference between the a and b horn, TLR331018?
It isn't the horn, it is the ackermann setting. B will have less off power, better mid corner steering. A will have more off power steering, less mid corner.
Print Wikipost
Old 09-22-2016, 07:52 PM
  #586
Fabulous's Avatar
Trader Rating: 42 (100%+)
When I broke the front pivot, the steel brace and hinge pins were fine. Kind of weird just the pivot broke.
Fabulous is offline
Old 09-25-2016, 03:16 PM
  #587
BLbound's Avatar
Trader Rating: 27 (100%+)
Any word on the new revised rear a-arms? Allowing easy a-arm flipping w/o drilling?
BLbound is offline
Old 09-26-2016, 09:09 AM
  #588
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
It's a running change, no hard dates. It's two holes, pretty much the easiest mod ever though.
Frank Root is offline
Old 09-26-2016, 09:39 AM
  #589
Trader Rating: 15 (100%+)
...Hey Frank some angled ball cups to mount onto the vertical ball stud mount to go with the new arms would be nice as well!
HeavyD99 is offline
Old 09-26-2016, 01:22 PM
  #590
Fabulous's Avatar
My vote would be to redesign the rear shock tower to allow a vertical ball stud mount to be mounted at the rear of the tower like on the 22 3.0
Fabulous is offline
Old 09-26-2016, 05:52 PM
  #591
BLbound's Avatar
Cool, thanks for the info Frank! And yes, angled ball cups would be sweet...I REALLY don't want to use those "other" angled ball cups...
BLbound is offline
Old 09-26-2016, 06:55 PM
  #592
This is also a good idea!
HeavyD99 is offline
Old 09-27-2016, 12:40 PM
  #593
Trader Rating: 166 (100%+)
If anyone here is running the aluminum pullys, did it make your car louder?
jpcopeland1 is offline
Old 09-27-2016, 06:08 PM
  #594
Fabulous's Avatar
Why would it? metal on metal (pinion and ring gear) would make it louder in which this is not the case. There should be no change in noise.
Fabulous is offline
Old 09-28-2016, 06:54 AM
  #595
Trader Rating: 149 (100%+)
Default diff oil help
what diff oils are most of you running on a small tight turn wet clay track running slicks? i am getting ready to build another set uf diffs for the indoor track.
skyline1015 is offline
Old 09-28-2016, 09:47 AM
  #596
TLRacing
Frank Root's Avatar
30 front, 40 rear. Sometimes, 30/30
Old 09-29-2016, 05:49 AM
  #597
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
what handling difference will we see with this diff oil setup as opposed to the stock 50 50??
Matt M. is offline
Old 09-30-2016, 08:39 AM
  #598
TLRacing
Frank Root's Avatar
Quicker rotation.
Old 09-30-2016, 11:53 AM
  #599
I'm still running 50/50 diff fluid in mine, I run at OCRC, if I dropped the front diff to 40 would I see much of a difference in rotation or would I need to go down to 30? car runs awesome..just looking for a little more rotation.
AJrollin is offline
Old 09-30-2016, 03:24 PM
  #600
Casper's Avatar
Trader Rating: 34 (100%+)
I ran 30K front at OCRC to start and I went back to 50K and liked it better. 30K actually made the rear a little less stable and the 50K front helped the car with better acceleration out of the corners.
Casper is offline
