Team Associated B6 & B6D thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 09-05-2019 | 07:30 PM
  #9136
Davidka's Avatar
I have always found my steering to function best with the servo horn turned one spline clkockwise from 90*.. It behaves more like a true center, relative to the steering bellkcrank. With the setting I usually have very similar end point settings to both sides of the steering throw.
Davidka is offline
Old 09-05-2019 | 07:56 PM
  #9137
Di_spencer's Avatar
Yes, either clock it one spline over or use the subtrim, the servo horn isn't meant to be truely vertical when the wheels/bellcrank are straight.
Di_spencer is offline
Old 10-10-2019 | 02:01 PM
  #9138
Default Gearing help
I'm new to 2wd buggy and just got a used B6 with a Hobbywing Quickrun 3650 17.5t motor. Car has 72t spur. I'll be running on carpet and unsure of pinion size. Where should I start?
DarthDad is offline
Old 10-10-2019 | 02:43 PM
  #9139
Di_spencer's Avatar
I would start somewhere around a 28 or 29 and see if you need to go up or down depending on the track.
Old 10-18-2019 | 11:39 PM
  #9140
D1360's Avatar
When you run 2 gears in the diff, do you leave the second empty axle in the diff? Why/why not?
D1360 is offline
Old 10-22-2019 | 04:52 AM
  #9141
No ..... because a single shaft is strong enough to handle the loads even a 5.5 on high grip carpet/astro can load it with. You would simply be carrying more rotating mass for no good reason.
RogerM is offline
Old 11-13-2019 | 08:14 PM
  #9142
Delete
weedsnager is offline
Old 11-17-2019 | 12:22 PM
  #9143
monkeyracing's Avatar
R/C Tech Elite Member
Is anyone aware of what it would take to convert a B6D into a short course truck? I’m having trouble selling the thing, so I may as well have some fun with it.
monkeyracing is offline
Old 04-19-2020 | 12:31 PM
  #9144
Default Love the paint job
Originally Posted by Lunchie
many of you will have seen this on facebook, but heres my B6 ready for carpet
Hey Buddy I love how professional your paint job is!! did you do this or do you know who can help me do mine? thanks so much !! bad ass looking buggy!!
justyjuice is offline
Old 06-05-2020 | 10:59 PM
  #9145
Default B6 build/setup problem
Brains trust, question regarding basic build/setup problem I'm having.
Trying to get the front setup but somethings off and for the life of me i can't work it out.
Using the kit measurements for the links (all spot on) then trimming to get the toe equal (which says to me the wheels are straight), the camber is way off on one side, ie left is correct (or very close) but the right is over -3
clearly something's not right, but i have no idea where to look and hoping someone might have a clue about where this might be going wrong
ShootHere_ is offline
Old 06-06-2020 | 08:21 AM
  #9146
I'm not an expert here, but I'd check the ball studs. Are they in the same locations, and do they have the same number and thickness of spacers? Yes those tiny .5mm washers change the camber more than you would expect.
estill is offline
Old 06-06-2020 | 03:43 PM
  #9147
Yes and yes, thats what's making this difficult. Logically this shouldnt happen if everything is by the book, yet....
Old 06-06-2020 | 03:49 PM
  #9148
Suspended
I have seen something similar on previous .1 cars, I wonder if there is a tolerance mistake in some molds
Losiracer12 is offline
Old 06-06-2020 | 05:00 PM
  #9149
​​​​​​In my experience, nothing is perfectly symmetrical. I've learned to trust my camber gauge over the length of the tie rods.
The biggest thing to remember about it, is that it changes as the suspension moves. Make sure your ride height is set left to right, drop the car from the same height, and measure. This part is my opinion, but the number itself doesn't matter. It just need to be set the with the same method each time.
estill is offline
Old 06-06-2020 | 06:14 PM
  #9150
Of course, but this basic setup so it should be pretty close
the trouble with uneven link lengths is that each side moves through different arcs, so different camber and toe changes on each side for any given load. Not good if you're looking for consistency
IMHO if theres a mechanical issue big enough to cause that big a discrepancy it should be pretty much visible from space, but I'm still not seeing anything
