Team Associated SC5M Thread >
Like Tree84Likes
    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Old 10-15-2015, 05:54 AM
  #931
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Stiffer spring in the front with heavier oil (I'm currently running 37.5 front with an orange spring from the previous kit). Drastically drop your drag brake or eliminate it. The mid motor won't need it. All mid motor vehicles like to be driven differently than rear motor. Make every attempt to carry corner speed through all the corners. You will end up using the brakes very little around the track. If you do have a corner you need to brake for do it prior to the corner and drive through the corner on throttle. When setup correctly you will find that being on the throttle brings the rear end back in line in almost all cases. I've never experienced the nose down issue over jumps. Try the suggestions above and see if that makes it go away.
bds81175 is offline
Old 10-15-2015, 05:56 AM
  #932
Moderator
bds81175's Avatar
Folks, when setup well this truck drives itself and is just plain fast. If you aren't experiencing this post your issues (RC related only please!!) or PM me and we'll try to get you straightened out. This thing just plain rocks.
bds81175 is offline
Old 10-15-2015, 07:40 AM
  #933
tmail55's Avatar
Trader Rating: 61 (100%+)
Normally is one or both of these (not in any order)
Butt slap << back end hitting the track hard enough to cause the front to drop in the air.
Fix(s) at rear
a. stiffer springs
b. stiffer oil
c. smaller holes or fewer holes in pistons
Drag Brake << motor slows (excessively) causes the front to drop
Fix(s)
a. Remove it from your ESC (set to 0%)
b. Turn up the throttle on your radio (throttle trim) << same as holding the throttle on a bit
tmail55 is offline
Old 10-15-2015, 08:36 AM
  #934
I should have stated, I've added no drag brake. I'm not sure if/what my esc has in it for a factory setting, I'm running the Works Team Flow.
BigReade is offline
Old 10-15-2015, 08:46 AM
  #935
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
my daughter truck noses down at srs also if I try to scrub....so I dont bother and just throttle up the face. Kinwald told me the truck is too light. He has to add brass just to get to legal weight. But he added like 100+ grams of brass, lol. I am referring to the brass for your rear traction issues. And HT Tucson is not a high bite track and I am not sure I would rate it medium. More like blown out and rutted.
Wildcat1971 is offline
Old 10-15-2015, 09:36 AM
  #936
I mean, I'm yanking wheelies down the straights, in my sc and my buggy. The buggy is only a 10.5, so not stupid power. I'd say the bite can be pretty high.
BigReade is offline
Old 10-16-2015, 02:55 PM
  #937
I'm putting one of these together. This is my first kit ever. Right now I'm working on the body.
Do the vents in the side help at all? They are not as well defined as the vents on the hood and fenders so I'm unsure where to cut.
John Sargent is offline
Old 10-16-2015, 03:10 PM
  #938
if you are talking about the vents on the doors, then no, they shouldnt get cut. If your talking about over the rear wheels on the back of the truck, then they will help a bit...but only if you do jumps.
the vent holes are primarily made for reducing parachuting on jumps
rekim is offline
Old 10-16-2015, 04:01 PM
  #939
Yes. I'm talking about the doors. The hood louvers are coming along slowly. I already did the six on the fenders, the three behind the "driver" and the big one in the center of the hood.
Old 10-17-2015, 10:26 PM
  #940
So I bought these two items for the front spindle.
http://www.amainhobbies.com/rc-cars-...c71013/p423519
and
http://www.amainhobbies.com/rc-cars-...c71034/p449718
After assembly, the m4 locknut will clearly not fit. M5? I don't have one to try. I wish AE would state what locknut you need if it isn't the stock m4 locknut.
NovaCX12 is offline
Old 10-18-2015, 12:13 AM
  #941
An M4 is the stock locknut that comes with the kit for all four wheels.
islandscott is offline
Old 10-18-2015, 06:00 AM
  #942
Jmuck69's Avatar
Trader Rating: 14 (100%+)
and
After assembly, the m3 locknut will clearly not fit. M4? I don't have one to try. I wish AE would state what locknut you need if it isn't the stock m3 locknut.
It does state in the instructions.
Jmuck69 is offline
Old 10-18-2015, 07:55 AM
  #943
and
One of the axles I got had bad threads. AE sent me two axles to replace the defective axle and one of them had bad threads. This could be your issue.
GonzoKY is offline
Old 10-18-2015, 08:51 AM
  #944
Trader Rating: 166 (100%+)
Originally Posted by Wildcat1971
my daughter truck noses down at srs also if I try to scrub....so I don't bother and just throttle up the face. Kinwald told me the truck is too light. He has to add brass just to get to legal weight. But he added like 100+ grams of brass, lol. I am referring to the brass for your rear traction issues. And HT Tucson is not a high bite track and I am not sure I would rate it medium. More like blown out and rutted.
Have you tried the brass c and d plates? I am going to drive mine for the first time today, when I ordered it I got a set of the 50 gram Yokomo under battery weights. Hope that helps with traction and forward bite. I noticed Cav ran bras at SRS. LRH is close to that much grip when they maintain the track, which will be much better come winter when its not so hot and humid. I just could not get my 22SCT 2.0 stuck enough in the corners for my aggressive driving style. Hoping the SC5M does a better job at sticking in the corners.
jpcopeland1 is offline
Old 10-18-2015, 09:24 AM
  #945
Trader Rating: 36 (100%+)
We run brass c and d plates and have good luck with them
mxturd is offline
