Team Associated SC5M Thread
#2881
You will have to use ProSC10/DB10/Trophy Rat parts that are available. a arms, hubs, axles, top deck, front shock tower, and ect. I know the rear shock tower and 25 degree front bulk head have been discontinued for the T5m and SC5M. Here is a link to the part number for the a arms, you get all 4. a arms
#2882
Does anyone know if the xfactory carbon fiber chassis can be swapped with the aluminum chassis directly? Or is the entire infinity setup required? I'd think you could do it but wanted to confirm. Anyone have experience using this setup? Is it worth the money?
#2883
Yes. Actually I just sold mine on here about a month ago. Yes it's a direct swap. Nothing more needed. It was very nice, however for me running on carpet it wasn't helping. The Chassis has lots of flexibility even at its stiffest setting. When it comes to running on carpet (high grip) I don't recommend it. For clay and dirt it probably works well.
#2884
CONVERT A SC5M to SC6.1 Steering parts
I know it's here but i can not find it.
What parts do you need to convert the sc5m steering inserts, blocks, axles etc to the 6.1 style
Is there a video of it being done
#2885
Returning guy
I built an SC5M for driving on a clay track a few years ago. It was my first build and I was still learning how to drive r/c. Then I got sick and was unable to enjoy any of my hobbies.
it took a few years and several trips to doctors around the USA to get better but now I’m back.
The clay track has been closed and now a brand new carpet track has opened. I see the SC5M has been discontinued and from this forum, I see that some parts are out of production. Should I try to get this car working on carpet or put it on the shelf and start over?
#2886
i am a newbie but I have just been given a sc5m to get my feet wet but when I am talking to my locals who are now moving indoor carpet and turf they are telling me that the sc5m is still a great car for all around
they said still lots of part out there stock and aftermarket
#2887
What tires are people running on carpet. The hobby shop wants me to use Proline Wedge 10147 on front and Pyramid 10154 on the rear. The radius of these is much larger than the jconcepts tires I used outside. The body rubs on them badly making an awful racket and dragging it down on corners
#2888
Anyone know if you can buy the inserts for the rear hubs that ball studs screw into?
#2890
91414 is the rear hub kit (as mentioned) and in that kit are the plastic inserts (2-hole/3-hole) that go on the ball stud side of the hub, 91416 is the blue aluminum nut that goes on the back of the hub that the ball stud screws into, they are not included in the 91414 kit … they are both discontinued, but available still on Ebay … if you just need a couple of either, send me a PM, let me know what you need and I can check, I should have a few … an alternative part # would be 91418, which is the rear hub used on the ProSC10, Reflex and Trophy Rat, the do not use either the plastic insert or the aluminum nut, they are solid plastic that you screw the ball stud into ...
#2891
91414 is the plastic insert that goes on the ball stud side of the hub, 91416 is the blue aluminum nut that goes on the back of the hub that the ball stud screws into … they are both available … if you just need a couple of either, send me a PM, let me know what you need and I can check, I should have a few ...
I lost the nut side did not check if the other side is still there will check it out
guess I want to find at least 1 backup of each
#2893
Just checked 3 I had loose, they are from B5m, T5m, and SC5m … which would all be interchangeable... and they range from 15.52 - 15.61mm … I almost always need to use the Associated 1733 shims to set the diff properly in the trans ...
#2894
Hey Gang I am wanting to build a new trans for my B5m and sc5m
what gear case should I use
what gears
bearings
diff
slipper or Eliminator
#2895
I'm not sure if this will be of any help to anybody, but if you're trying to fit a body on your SC5M that needs the rear body posts moved back, you can retro an SC6.1 rear body mount pretty easily. The 4 mounting holes are all in the right spot. The only difference is that the male pins surrounding those mounting holes are a different length and width than those on the SC5M mount. I trimmed their length down to match the SC5M posts, and didn't worry about the different diameter. Once tightened in place with the rear bumper all mounted up, everything is nice and rigid and now I have body posts that are further back.
