Team Associated SC5M Thread
#2236
One question, how can measure the offset from wheel ? I have the stock from kit and some other from other SC. The +3 is mm i think but how measure ?
#2238
FYI the drilling of the holes for the shapeways is optional(states it on the instructions) I did it to my b5m, worked out well, but now I am running it in my SC5M no holes drilled and haven't had a problem. Constantly top three.
#2239
Any news/rumors on an SC6M? Would love a SC to go with my new buggy, but I'm having a hard time pulling the trigger knowing that there's a very high probability that the new platform is around the corner.
#2240
hey everyone - I am trying to follow a new setup that has "25g brass c mount" listed. Is it this part even though they are not listed as compatible?
https://www.amainhobbies.com/team-as...c91690/p507426
Thanks!!!
Thanks!!!
#2241
Thanks!!!
Thanks!!!
#2242
Thanks, that does look like it would fit better. This is the setup I am trying to use:
http://site.petitrc.com/setup/associ...1231/setup.pdf
I am running on high bite astro with the same tires as this setup... hoping to get something I can drive hard without traction rolling.... I feel like I have to take the turns super slow...
EDIT: Or maybe this one with my current tires? http://site.petitrc.com/setup/associ...way2015080709/
#2245
I have used the stock ones in my T5M and SC5M with no problems.
#2246
1) Use green slime if you have it
2) Don't compress the bottom cap until after you've inserted the rod.
Both measures will help prevent the insertion of the rod (particularly its threads) from damaging the O rings.
#2248
