Team Associated SC5M Thread
#1726
when i had a 22SCT, my thrust bearing washers completely disintegrated and others had the same issue along with snapping diff bolts and the solution was to buy associated parts. once i did that, i never had any issues. weird that you and your friends have seen failures with the AE stuff.
#1728
So tell us what you are after,speed,torque or best bang for the buck.
I myself use a Futaba S9452. Its not the fastest or most powerful.
Speed: .13 sec/60° @ 4.8V
.11 sec/60° @ 6V
Torque: 102 oz-in (7.4 kg/cm) @ 4.8V
128 oz-in (9.2 kg/cm) @ 6V
#1729
But I got a good deal for a Futaba S9352hv which I installed in my SC5m. Got it NIB for 50€ instead of 130€ on eBay
#1730
I use a 1015 (different Distributors), nothing to complain.
In my other cars I mostly run Savox - never had an issue!
#1731
1015's are good, I think anything that gets you at least 150 lbs. of torque and is aroung .10 should do you just fine, I have one of the new Reedys, and its too fast, ended up slowing it down via my radio settings for digital servos. Smooths it out greatly. Truck has a s***load of steering that needs to be calmed down.
#1732
I just purchased the sc5m and was wondering what is evrybodies choices on batteries and which esc will work the best with it. Im looking to go with either a 13.5 or 10.5 motor.
#1733
Hey guys, I have a question and not sure if it's been covered already or not. I've just recently purchased an SC5M and I'm running a 13.5 Tekin Gen 1 motor with boost on an asphalt track with high grip. My question is would the ball diff give better rotation than a gear diff? It's rotating decent now, and I'm adding sway bars to it soon. Any thoughts on this?
#1734
MUDVAYNE,
Race mine on high traction sealed clay off road or sealed asphalt on road, with the same setup. Only changes are the ride heights >> on road 22mm front and 20mm rear plus tires to fit track.
Haven't tried a gear diff.
The on road gear diff cars I race are tail loose compared to the ball diff cars.
http://site.petitrc.com/setup/associ...bbies20160109/
#1735
MUDVAYNE,
#1736
we run a series here on really loose dry tracks, we added brass c & d plates, and 35 grams more weight after that to the rear. also proline blockade m4 tires and run rear shock on inner most hole on arm and rear shock tower(that helps for loose conditions). You have to add alot of weight to the mid motor cars for outdoor, since they lost weight in rear moving motor to the mid configuration. hope that help, but tires outdoor are 90% of setup and you have to add weight, overall i think with the c & d blocks brass and other weight i added close to 60 grams of weight to the rear. hope that helps
#1737
Second trip to the track. Truck is working really well. It is so much more than my old SC10.2. This truck seems to be so stable, not twitchy, goes where you point it, holds the line, does not spin, just a lot more fun to drive.
I checked the ride height tonight. I am 33mm front and rear. I can turn under my brothers SC5m with ease. His is riding way to high.
We had a good time tonight on the new layout. Way more technical, turns, double, triples, left, right, gas, brakes, power, turn. Fun track. This layout is only 2 days old so the blue groove was just starting to build tonight.
Buzz.
Buzz.
#1739
I have mine setup per the manual. Same shock settings, same oil, the included springs. What settings can I change to lower it? If I left it off the ground, just set it down I get about 10-12mm sag. That is a guess, have not measured it.
If I can lower it and make it faster, that means I will be that much faster than my brother, that is a good thing. You know, brotherly love and all.
Buzz.
Buzz.
