Team Associated SC5M Thread
#1516
very little torsional "twist" and no flex in the middle. i gotta say since the sides of the original chassis bend up the stock rails dont lay flat..but do snug downwhen you screw them down to the flat carbon chassis..
#1517
Thanks for the reply Guess I'm placing an order then.
#1519
Just stocking up everything I need for the upcoming season (although it started snowing just now). Anynone some ideas on what parts I might break? I havent broken anything all winter, just 1 chassis head due to a very unlucky slide down a jump onto a wooden plank...
I could upgrade some stuff for improved handling AND durability (no bling blling wanted )
> Front Arms (71008)
> Front Bulk Head (91364) **
> Front Hinge Pin Brace (91371) (Is the aluinium for 4times the price really worth it?)**
> Aluminium steering set (91392)** (really worth it? costs lots of bucks)
> Front Caster Block (91400)**
> Steering Block set (91404)**
All parts listed ** could be used with my B5R...so thats a plus
Any other parts that I should have?Which ones wear out fast (steering blocks?) Or any other aluminium upgrades that are really worth their money?
> Front Arms (71008)
#1520
> Front Arms (71008)
> Front Arms (71008)
Steering set isnt needed but makes it feel alot less flexi threw a turn
As spares i say arms casters and steering blocks suould be good
#1521
Thanks! The Brass Bulkhead (91365) costs nearly 50$ here in germany...thats either worth the money nor a good deal...
#1522
i want some proline split-six beadlock rims for my sc5m but im totallt confused what model number to get i think from what i read the sc10 ones but can someone confirm which ones? i know they also make aluminum beadlocks rings..i plan on ruinning bandito street tires for bashing around up and down the street. i plan on glueing the tires down if necessary
need imput
need imput
#1524
is there a 8.5mm to 17mm hex adapter for the sc5m?
#1526
#1527
Avid just released their updated bell cranks for the B5/T5M/SC5M Series.
http://avidrc.com/product/5/accessor...cessories.html
#1528
#1529
are these recomended to adapt 17mm wheels to my sc5m ?
http://www.ebay.com/itm/272060370114....N36.S2.R1.TR9
#1530
Setup Advice...
I have searched and read through a lot of this thread before deciding to asking for some advice...
I have a SC5M that I have a love/hate relationship with. It reminds me a lot of a sour patch kid in the aspect that sometimes its sour and sometimes its sweet.
I bought the kit right after it came out with the intention of running it for a stock SC points series which it did well enough in, ended up 3rd overall but the truck has always been unpredictable. I decided not to run it after the point series unless they needed a fill in for 2wd.
I recently decided to give it another crack and set it up for Mod 2wd SC. I will be posting my actual build sheet for review. Any advice would be great. It is basically Cav's setup with a few changes.
What I am fighting is the truck has a tendency to nose over and sometimes roll on corner entry and the rear end breaks loose on exit. I am also having a hard time getting the nose to drop in the air unless I am scrubbing the take off and countering it with a little throttle in the air.
I am currently running 37.5wt 1.5pistons in the front shocks with Grey Springs and 30wt 1.6pistons in the rear with Factory springs. I have both the Brass C/D mounts installed. I am running a shorty battery with the 50gr weight under the battery. Battery is sitting about 6-7mm forward from rear of truck. NOTE: I have not run the truck since adding the 50gr weight under the battery.
I also should note that I am racing on indoor high bite clay at IR/CR (Intermountain R/C Raceway).
Last edited by Jade67; 04-27-2016 at 10:42 AM. Reason: Added Details, Build Sheet, and Setup Pics
