Tekno RC EB48SL Thread
#16
I am interested in this, whats the word on how it well it would work in traditional 1/8 buggy usage (4S, buggy sized electronics) when you get the right straps and motor mount insert?
I am figuring with the larger bearings we could be more durable, and then I could share parts with the new SCT410.3
#18
Curious if the can the weight down enough for pro4HD & 2s batteries to make a 8-10 Min main?
#19
Depending on track and cooling, 8 should be possible with the current crop of large 2s packs, though you'll definitely see fade by the end. 10 I doubt, as I'd probably have a hard time doing that with my SC these days with how hard I drive it. If you're really easy on throttle and tend to coast into a turn instead of brake into it, then it might work though.
#22
I contacted SMC about doing a 4 cell shorty, 4s1p 2200mah pack but haven't heard back. I run a 2s2p 4400 SMC in my SC so running it in a 4s configuration would be awesome.
#23
Tech Legend
well, I think I am pretty set on my mind to go with the eb48sl.3 if it becomes available here.
I'll probably use my regular buggy gear, a Viper VTX8 and there VF1900kv motor.
am I correct in assuming I need these items:
- Regular motor cam
- Buggy sized straps
I think that's about it?
- Regular motor cam
#24
- Regular motor cam
- Regular motor cam
As for the battery straps you'll prolly need the buggy ones unless you're running a smaller 4s pack. I use the SC straps with my ECOPower 4s packs, they're just long enough for that pack.
#26
Working on building a SL with the spares I currently have and would like some advice from others who have built or run them. Here is what I am planning / contemplating at the moment.
-BCE chassis
-RX8 with PRO4HD 4300 on 2S 7200Mah SMC batteries / not sure what other motor battery combo I should try for a 10 min main
-carbon fiber towers
-SCT410 lightened outdrives
-SCT410 tapered front Drive shaft / rear drive shaft
-LCG motor mount/plastic rear center diff support
-Would like to go with the stock EB48 A arms, hubs and axles for improved bearing diameter and a wider stance or is this a mistake and will add too much weight?
-Aluminum ball / rod ends
-Alumium screws - strategically placed
-Titanium turnbuckles (Lunsford)
Where did I go wrong or need to make changes?
-BCE chassis
#27
I believe that the BCE chassis is no longer available, unless you already have one or plan on buying one used.
#28
I'm thinking of building one up with a pro4 1850/rx8 combo that I have sitting around and all alloy screws etc with SMC 4s 4600 shorties.
#29
Anyone else use the EB48 arms, axles and hubs instead of the SCT410 gear? pro's cons?
#30
I've been running an EB48.2 that I lighten the center driveline of. For the arms to not take as much extra weight, I run the arms from the EB48 (not the extra tough ones). I like using the full EB48 corners because of the extra heft and not needing to replace CVD pins and such anywhere near as often. To make 10 minutes would be a challenge on 2s, not likely because of battery use (7600 is easy to get now), but because of heat. Using a 4s setup with a light 4s pack (2s stick size or shorty brick size) should work out well for a powerplant to do 10 minutes, though we run ours here on 2s and 5 minute mains.
