Tekno RC SCT410.3 Thread
#5461
Motor is new and smooth. No slop in the motor. And this was on the stand in my dining room. Not made it to the track yet. Yep priest.
#5464
is there any binding in the drivetrain? everything moves freely?
tried another lipo? is the motor or esc overheating?
shock oil and setup shouldn't effect the issues it sounds like you're having... seems like an electronic issue for sure. i had a similar issue once with a bad sensor cable, caused it to act kinda like that..
I wasn’t suggested that my setup was causing it. Rather, just putting the info out there for feedback on possible problems or suggestions for setup and upgrades...that’s all.
The day I had this problem, I also rebinded the radio and recalibrated the esc a couple times as well. I haven’t been able to take it back out since I changed the motor, esc and rx.
#5465
Well, and maybe some holy water. It was a used truck. Never know......
#5466
Does anyone know why they quit making the 8X1.4mm conical pistons?
I found a set for my truck but just wondering why they are not made anymore when they are called for on many of the setup sheets.
#5467
Tech Legend
I think at the time on the pistons they were not really being used. now, they are a hot item, not sure why tekno hasn't brought them back though. I ended making some of my own.
So is there a current hot carpet setup?
Right now the main issue I am seeing I would like to correct is that on some of the jumps, mind you they are abrupt the nose down issue is really rearing its head. you can see here (my truck is the white and black one)
https://www.youtube.com/watch?v=zUSJ-KO_HWI&t=155s
Other classes the vehicles in particularly on the bump on the straight sale over this perfectly. The tekno 4x4 SCT though will nose down every hard, end up having to hit the brake right before it then gas up to punch over.
#5468
#5470
The tekno has a distinct noise to it over other 4wd's. You definitely know who is running one but the sound. Just make sure your mesh is shimmed right with your diffs and your spur, diffs greased properly, and run it.
#5472
I'm not sure this is the exact reason, but I run the Losi pinion gear and it seems quieter than all the guys running the Tekno pinion.
#5473
Oh I forgot to ask if anyone is running the EB48 drive shafts and outdrives? Guys at my track did it and it looks beefy as hell.
