New Schumacher KF2
#106
I believe the axles are interchangeable. I was just curious because I broke 1 then the next heat race another broke one of his (also a KF2 and wasn't a hard crash) then the night before someone else (also KF2) broke 1 side then broke the other side right after.
#109
I also broke a front axle in KF2 last weekend on high grip carpet track. I didn't even hit anything it happened after a little bit harder landing when front wheel touched the surface first and it had about 30° angle. It broke where the hex starts and bearing ends. It has never happened in my old KF.
#110
I don't have any experience on astro and clay so it's hard to tell.
#111
We are also running high grip carpet and the carbon chassis is def alot better. We weighed them and it was a 53gram dif which is helpful in stock racing.
#112
I went ahead and bought the carbon fiber chassis, the big plus is in run 17.5 so the weight loss is a huge plus but am I correct in saying this carbon fiber chassis will have more flex then the aluminum stock chassis giving it more grip.
#116
Can anyone tell me how this stacks up to the Serpent Spyder SRX2 MM?
#120
HI,
I ordered recently a kf2 to have something different in my country (Turkey) I won't have any local support at least for a while so should stock some spares to end up the races. I race only 13.5t superstock on a tight indoor carpet track with medium grip level.
-My budget is limited so I should buy as few as possible spare parts. I assume Wishbones, hubs (don't know ıf I would need all 3 of them ?) rod ends are must have. What about front shock shafts, hinge pins, front bulkhead , belt or any other parts ?
-For setup I will order 5 degree yokes and some springs but don't know which springs should I have for my conditions described above . I'm totally unfamiliar with the car and brand
