kyosho electric offroad
#918
foolio,
If you rotate your rx 180 deg. the servo plugs will be under the cockpit area and should allow pleanty of room.. It may also make for a "cleaner" install.. JMO..
another suggestion, mount the rx on the chassis w/ the servo leads facing back and inside.. This will allow somewhat easy access the the freq. dials (would move them to the outside endge)..
Just a sugestion..
Just a sugestion..
#919
Any one know how to eliminate or reduce the torque-steer on this buggy? My zx-5 seems to pull to the right under heavy acceleration.. I am running box-stock w/ 40 wt shock fluid front and rear (and a GTB 6.5).. I am also using the front one-way..
#920
Loose the front oneway !and use the ball diff with the oneway on the driveshaft. This is how all of us at RCE got rid of it !
#921
Originally Posted by ALJR
foolio,
Just a sugestion..
Just a sugestion..
#922
Where can I order the Shooter's brace?
#926
I decided to go ahead and use the "ALJR Body Mod" to get the clearance I needed for the fan. To my surprise it was really easy and turned out quite well. All I used was heat gun on high and pointed it directly at the spot I wanted to re-form and voila! The heat gun softened the lexan and pushed out a nice little bubble. Now I have about a 1/4 of an inch of clearance where the fan was once hitting. I can really push on the body and wiggle it around and the fan still won't rub. It really doesn't look too bad either, but hey, I am more of function over form guy myself. Thanks ALJR!
#929
Your welcome foolio! Glad I could help
captain america, not too sure what your looking to spend. But I love my JR9000s servo. I used it in my 1/8 buggy over the summer and its now in my zx-5 for the winter (and its going to stay in it)..
The servos specs:
Torque: 128 oz/in @ 6V
Speed: .06/60 degrees @ 6V
Dimensions: 0.83x1.59x1.50 in
Weight: 2.2 oz
Gears: Metal Gears
http://www.horizonhobby.com/Products...dID=JRPSZ9000S
The servos specs:
Weight: 2.2 oz
Gears: Metal Gears
#930
Hi ALJR.
The JR servo you're using seems to compare favourably with the airtronics 94162Z. Torque and weight are pretty similar, but the JR seems quite a bit faster in terms of response time. To be perfectly honest, I don't know if a difference between 0.6s and 0.18 sec will really make such a difference to me. Perhaps I'll try the Airtronics to start with, and if I really notice the delayed steering response, I may just swap it for the JR 9000S.
Compared to the electronics I was using 14-15 years ago, even the crappiest modern servo probably has F-1 performance
