kyosho electric offroad
#6091
#6092
A few pics of the 4WD 10 scale king :
#6093
Casper you posted your setup anywhere of what you are running in you sp. Just trying to find out if I am missing anything. Now looking for a rb5 too.
#6096
not sure if this has been asked before, so I will ask anyways.
I have the lazer zx5 sp edition car and love it.
It works great with the basic setup on the dirt tracks that I have tried it at, but when I tried it at our local indoor carpet track it became a handful to drive.
...The traction is awesome, but that may be a problem.
If I go into the corners a little too hard or fast the car tends to barrel roll from the traction. When I take a corner one of the front wheels come up off the ground as well.
Don't remember whether or not the sp kit came with front and rear sway bars or not, but a friend of mine with a zx5 non sp kit bought a Associated BJ4 sway bar kit and installed it on his car, and with some tweaking got it working pretty good...
rcdave
rcdave
I might try caspers suggestion of reducing droop also, although I reckon this might lead to nasty chassis slap off the rather large jumps at my track.
#6098
The little manual that come with the hubs give you the stock settings.
I can't remember what they are right now. I think the back ones are E-E
I have them in my bag to put on the car on wed though. I will go open them up if you don't have your insert with them anymore.
#6101
I have been running 30 losi in the back, with the stock oil up front, very nice. Was out-turning and accelerating B-44s tonight (all same skill level drivers), and missed the win from getting caught in lap traffic.
Dang, the SP is durable, took some really bad landings, rear-ended a few cars trying to get past about 6 people and so far I have only bent one turnbuckle, and broke one front arm that was my own fault for not putting the hinge pin retainer screws in and gave a leverage point for an easy break...
#6102
I am using shumacker tires all around, with blues up front and gold in the back. The traction is awesome, but that may be a problem.
So my question is what should I do? Can I buy sway bars front and rear from Kyosho for my car? Try thicker oil, harder springs?
Can I lower the center of gravity on the car?
The car worked so well outside that I thought I could just bring it inside and it would be great, but I need help.
Thanks in advance.
rcdave
Thanks in advance.
rcdave
Hi mate,
here in the UK most clubs run indoors on carpet for their midweek races so I think I can help you out ...... everybody who has driven my car has ordered an SP ready for the following week!!!
It's a little different from my outdoor setup, so much so that I have a spare pair of shocks in the box with the correct pistons / oils / springs.
Let me know if you have jumps in the track or not as that makes a difference too and I'll post you up a set up .... maybe PM an e-mail addy so I can send the set-up sheet.
As Casper says, low and stiff ......... of and run Yellow compound tires all round as the difference in tire construction between yellow and blue make them feel very different and mixing them on a 4wd car can be "interesting"
#6103
"The clamping wheel hubs are nice to have and very convient but not a must. If you are looking to get alum rear braces the Kyosho ones are better then the PN ones in that they are still alum but come with spacers to allow you to adjust the antisquat and toe in with inserts. A nice feature."
Casper, do you happen to have the part number for the rear braces you spoke about in the above quote? I can't seem to find them. Also, I can't seem to find any info on the center shaft one-way either.
Thanks,
G
Thanks,
G
#6104
hey does anybody have a part no. for the kyosho rear aluminum toe plate? i have the aluminum anti squat and fron kickup plates but didnt know kyosho made a toe plate in aluminum. part no.?
