Yokomo YZ-2
#2538
Couple of Questions on the Ymax Conversion. I have all the parts to pull it off, along with the Factory RC kit, but have a few questions below:
1.) Is it best to use the BMax 2 rear arms? - I have sets of YZ2's, BM2, and BM4's that I can use on it.
2.) If I use the BMax2 or BMax4 arms, do you know the proper hub and bone/axle length that should be used for such kit? I assume the BM2 bones and 5.0 hubs are best, but let me know.
3.) Anyone know where to get one of the BMax 2 idlers - I have one, just need a second one.
Thanks in advance.
Thanks in advance.
#2539
DRove the car for the first time on Wednesday and it was crazy good. Did everything I wanted but it kept wanting to flip in one spot of our track. It's a jump and the end of the lander is a 90 degree corner and I can't land and try to accelerate hard or else it will flip over. I believe the car is too soft and is bouncing too much. The track is high grip Astro
So what pistons fit this? My LHS had AE pistons in stock, will they fit?
#2541
Thanks in advance.
Thanks in advance.
However, if anyone has a spare B-max idler gear and/or a gear cover laying around they would be willing to part with please let me know. I have all the other parts but struggling to find an outlet for those two parts online....seems everyone has discontinued these items. Happy to work out ways to pay for such parts.
Thanks again.
#2542
At the risk of sounding stupid, can someone clarify the spacers used in the Set Up sheet for me with regards to the steering rack? There are two spots near the rack that have spacers listed, I believe the 'top' one is for Ackerman, similar to my B5M, but what is the lower spacer meant to adjust?
#2543
#2545
First, I will agree these set-up sheets are a little more complicated to understand at first glace, but once you get them down, it's not to bad,
Front Suspension:
Steering Rack Section Drawing. The two boxes are designed to define the amount of spacers below the steering arms (normally 2mm), and the amount of spacers under the ball studs on the rack itself (normally 3mm).
On the front arm and front hub carrier illustration, the up and down arrow with the red dot highlighted, shows if the hub is shimmed down or up - normally, the thicker bushing is on the bottom (thinner one on top), so the red dot is on the up arrow, showing the hub is shimmed up.
On the side illustration of the hub, it shows the castor setting, shims under the bump steer ball stud, and if the red dot is highlighted near the back of the carrier, that is meant to show placement of the spacer location (normally, shimmed in the back).
Rear Suspension:
The one area that is a little weird is the hanger illustration. If the red dot is below or above the rear hanger, that shows the location of the 1mm shim. Normally always below it. Same thing applies to the front hanger, but it is normally always below it.
Only other one is the S-M-L wheelbase - if it is S, they the shims are in the back and no shims in the front of the rear carrier. L, would mean opposite, and M means an equal shim in the front and back.
I think that is the complex parts. Hope that helps.
#2549
Any chance this wheeler is getting an update soon?
I saw a lot of them on sales overs the holiday season
#2550
My guess is you don't see much of anything new until later 2017, or something in 2018.
