Basher BSR BZ-222 1/10 2WD thread
#181
I have a question for you guys who've had substantial bench time and have converted your 222s to mid-motor. In all of the pictures I see with mid motor, the transmission has been flipped 180 obviously, but then the motorplate and all of the gearbox stuff has been flipped to the opposite side of the case. I was just curious if there is something that prevents the tranny to just be flipped and have the motorplate/cover on the opposite side without taking the gearbox apart and moving the parts to the opposite side? I may very well have missed something, just curious.
#182
Senseless motor...
#186
I've been wondering about this buggy actually. it might be my first kit I purchase for myself. Would anyone suggest this as a first build for someone who just wants a cheap racer to take to the track once every few weeks?
#188
No, actually I've ordered various parts which I'm waiting for, mainly the normal stuff that breaks but also the metal front hinge pin holder & metal suspension pin balls. These are what disintegrated on it's first outing causing a rear hinge pin to rip itself out from the holders, though I repaired it by making 2 new ones from some upper shock mounts. It's sitting ready for another go next sunday.
Just to report, the short run it did get was on our damp dirt track. I was using Team C kit ribs & ProLine Holeshot mediums & 10k diff oil. I found the car was wanting to swap ends out of corners & fishtail along the straight (hence me clonking the piping & breaking it !)
I used my TC02C Evo from then on with the same tyres & ball diff & had no such troubles, car felt good.
I think I need to go heavier on the diff oil, maybe 20k as it needs more forward drive instead of just spinning the inside wheel on the bends, even at the expense of some steering. A ball diff would better though I'm sure.
I'll report on its next attempt, hopefully on the 14th
#189
Dandare, what motor are you running on yours? I'm trying to get mine set-up for 17.5.
#190
Scrapped it...
I am looking at a Durango DEST210 stadium truck so I am reading a thread on here about it as well. I just read a post saying the exact same thing for both the Durango buggy and truck having had this same issue. The earlier models came with the same style braces as this buggy. The later models fixed it by making the newer braces with the pin fitting directly into the brace instead of using the balls. Just found that interesting that its not so much a 222 issue but rather a "master" design issue. Perhaps the updated Durango parts will retrofit to this buggy.
#192
Hey Dandare and for those of you interested....
#193
Carbon shock towers and titanium hinge pin braces are installed. Anyone find a suitable shock piston replacement? Also the rear bulkhead ( shock tower mount) really needs an upgrade. It's just so soft and allows so much play in the rear tower. I guess that will keep it from breaking? Hopefully I'll get back to the track on Sunday.
#194
#195
The Team C ones fit, part No. TU0250-7. The shaft hole on these is larger but they do work well.
Front - Black
Rear - White
Before fitting the new pistons I slid a nylon washer (mine happened to be 0.85mm thick but this isn't too crucial) onto the shaft first then refit the metal kit washer then the piston. This was done as otherwise for some reason the piston becomes tight at full extension.
Front - Black
Rear - White
