Indoor Clay Tires Thread
#46
The main tire that is being pushed at the 1/10 buggy track here (Champ Stadium in Sagamihara) is the Panther Switch 2.0 with PL closed cell foams. They work great on my RB6 as long as the track is still somewhat damp but as soon as the track starts drying up then they get really loose. I have run a set for about 5 or 6 practice days and they still have a lot of tread left on them. A couple guys run them on their SC6s as well but they go through them quicker due to the extra weight. The shop also carries the AKA Evo Deja Vu tires but I haven't tried them out yet. All the racers say that the Panthers are better than the AKAs on the track so I just went with them. I want to try some different setups so this thread will be very useful when picking the next set of shoes.
#47
yeah I've the same problem on our local track
when it's damp the aka handlebar clay work great but as soon as it dries the buggy is all over the place
really looking forward a grippy tire for slippery hardpacked tracks with little dust on top
I'm running a light setup on my MP9E so maybe it doesn't help
#48
in my 22-4 I am really digging Typos up front, with Chain links in the rear when the track dries up a bit. Maybe not in 8th scale, just throwing out what works for me in wheeler class.
#50
I've been running ions on my 1/10 2wd on the clay track I run on. They slide around when the track is wet, but when it dries out a little bit, they really hook up nicely.
#51
Are you running at the rc clubhouse in warren?
#52
It probably too difficult to gauge, but....
"IN THEORY" (Given track conditions do change, and watering etc and continual wear by cars also racing on the track)
Do people find changing from one tire to another between rounds maintains the traction consistency? All things being equal, you have different pattern tires with different inserts, or even the same inserts...
Has anyone done a back to back test of lets say a
Gold BC with AKA red
vs
Gold BC with DT
vs
GOLD BC with Open Cell
vs
Gold BC with PL Blue insert
Obviously there are TONS of variable and I don't know that one could find a fair comparison. Realistically, the environment couldn't change and it seems to me the testing would need to be in a sort of Vacuum to get the kind of results you need.
Its no wonder people go poor with various tires and types and compounds.
I did appreciate the feedback by Teufel and his reporting.
In all honesty, for me, our Primary indoor track is carpet and in many respects the "Tire war" is over. There are no Pin style tires allowed and ONLY SC are allowed foam tires. Most everyone runs a variation of a slick tire and we use a controlled sauce. It does make it nice only having a couple of tires in my box depending on the layout and how much traction is laid down. I don't go thru nearly the tire wear, as when we raced on dirt. Folks still run on clay and depending on how abrasive the track gets, as Zak pointed out, I have seen people kill a pair of tires in a Club race in 1 night of racing.
MOmo
vs
Gold BC with DT
vs
vs
MOmo
#53
The electrons seems to grab the clay very well on a 4wd, but going to try the bar codes next. Been told they are still doing very well for the pro's on clay
#54
back for a few feedbacks
I'm running aka handlebar tires in clay compound based on a famous local driver advice but I don't like them at all (lack of precision and bite) for the conditions we have now which are:
- hard packed with a few bumps starting to form but overall the surface is still smooth
- dust on top (track is watered once a week)
- slippery
I tried some city blocks in super soft just for fun and it was a night and day difference... in a good way! they did great in these conditions
IMO the best tires suited for this track would be a tread with multidirectional and low profiled pins in super soft compound.. any suggestion?
do you use particular tire inserts indoors or sauce or anything special?
- slippery
Depending on the amount of dust I would be looking at a tire with a little more pin in supersoft compound. Gridirons, possibly Impacts. Handlebars will likely work as well but I'd be running SS not clay compound. When the new Chainlink tire gets released that will probably be your best bet in AKA rubber.
Track looks awesome!
#55
Might seem odd but the Panther switch tires well broken in with wear work good on a hard packed mixed clay surface . If it stays moist and somewhat dry they still work good .
On hard packed pure clay that is not real wet smoother low treaded tires work better.
#56
vs
Gold BC with DT
vs
vs
MOmo
vs
Gold BC with DT
vs
vs
MOmo
#58
Dirt webs seem to be a favorite chioce at the local track.
I've ran them a bit and they do work well, rears seem to me to work Better than the fronts for me. They do,need to be broke in, but doesn't seem to take as long as the Bar Codes did or needed.
Chainlinks?
I've ran them too. For my local track, they aren't real good until about half the tread height is gone, then they're pretty good. Can't say for sure if they are better than other options, but they are a solid choice. I think it's a preference thing. I'll probably end up getting a fresh set and try them again and see if I can find a setup that likes them more.
Chainlinks?
#59
At my local track, OCRC, the preferred tire would be the JC Dirt Webs, or the JC Bar Codes. I race a tlr 22 mid motor with a 7.5 turn sensored motor, and the best tire for me right now is the dirt web. I have them worn down a lot, and they seem to be really good when the track comes in. The dirt webs are really good at most tracks i have gone to, and for me they wear fairly good. I had been running bar codes before using dirt webs, and when they had worn down, they lost all traction, and my car would just spin. When the track is a stickier clay, you can use a slick on both the front and rear of the car. Also, I have ran JC new smoothies at big races like Surf City Classic. They are really good when there are a lot of people racing, especially when top pros are also racing because everybody takes the same line, which gets a blue groove in the track. My favorite tire at the moment is probably the smoothies, but the most consistant tires i run are the dirt webs because i can run my most consistant laps with rhem, and they hqve good side bite and drive out of corners.
Hope this helps anybody that needed help with tire suggestions for an indoor clay track.
