o.s. engine breakin
Old 08-29-2005, 08:51 AM
wlvrn's Avatar
Default o.s. engine breakin
this weekend i finally got a chance to break my new o.s. 12 in. set the carb to what the book say and pulled and pulled. finally it started. it ran for about 2 mins then died. i pulled and pulled and nothing. replaced the plug and it acked like it wanted to start but after some pulling nothing. could the new plug be bad? when breaking in engines how many, if any, plugs should i go through
wlvrn is offline
Old 08-30-2005, 02:10 AM
Team Duratrax's Avatar
Its a common problem. Replace the batteries in your glow ignitor and prime the engine.
Sean
Team Duratrax is offline
Old 09-03-2005, 04:02 PM
wlvrn's Avatar
done that. didnt work. i just got done messin with it and its not putting fuel to the carb. what is the cause for that? i took the tank out and emptied it out and i can blow threw it fine. is that good or bad?
wlvrn is offline
Old 09-03-2005, 08:12 PM
An engine that has lost its compression would be hard to prime but thats definetely not the case seeing that your engine is brand new.
For now blow through the lines or put a drops of fuel down the carb.
Are you blocking the exhaust and then yanking the recoil to prime the engine?
Sean
Old 09-04-2005, 08:02 AM
wlvrn's Avatar
yes. and no fuel goes to the carb. ill try putting fuel in the carb today and see what happens. thanks TD !
wlvrn is offline
Old 09-04-2005, 10:02 AM
Platinum_Racing's Avatar
One thing I always do when I can't prime an engine is remove the line going to the carb, then I block the exhaust and prime it. When the fuel reaches the end, I put the line back on and give it a final yank.
Platinum_Racing is offline
Old 09-04-2005, 11:33 AM
Trader Rating: 28 (100%+)
To prime my engines:
Open carb with servo electronics off
Kink off the pressure line at the tank
Flip the tank lid up and down a few times
You should be able to see the fuel go thru the lines to the carb assuming you're using clear line.
You may have to lean the hsn a bit if it's to blubbery even to break in. You're elevation and air density may be different from the place where os wrote their manuals.
jbrow1 is offline
Old 09-05-2005, 09:36 AM
wlvrn's Avatar
thanks guys. i took it out yesterday and put some fuel in the carb and it pulled over soooo hard. i took the plug out and pulled and it pulled easy. put the plug back in and pulled. my god did it pull hard. its on my work bench now waiting to get tore apart. what could make it pull so hard?? when i pull the starter its like it has super compresion or something.
wlvrn is offline
Old 09-05-2005, 11:25 AM
losi jon's Avatar
sounds like you are flooding it.....take the glow plug out and turn the engine over a few pulls...try leaning out the low end a little to get it started,then once you do you can richen it back up for break in.
losi jon is offline
Old 09-06-2005, 06:54 AM
wlvrn's Avatar
so beings that its pulling so hard and without the plug pulling easy means its fludded?
wlvrn is offline
Old 09-07-2005, 06:48 AM
thats sad that you know so little
plug out means no seal obviously makes it easy to pull
my suggestion for lack of priming carb possition try paying with the carby open or closed while priming should prime best with it closed
are obviously over priming if it gets to hard to put take the plug out hold the truck upside down and turn the enigne onver a few times to empty it then reprime
dont keep pulling it when it floods you will kill your OWB or pullstart
just get clear fuel like and when the fuel is close to the carby give it 2 more priming pulls then try to start it
merc-blue is offline
Old 09-07-2005, 07:42 AM
That was hard to understand but i think i know what you are talking about.
wlvrn - These 2 sites will help you out a lot.
http://www.rcnitro.com/rn/articles/index.asp
http://www.rccaraction.com/rc/articles/index.asp
Sean
Old 09-07-2005, 09:39 AM
wlvrn's Avatar
thanks td
wlvrn is offline
Old 09-07-2005, 09:52 AM
I find it easier to prime with the carb fully open. I guess it's a matter of opinion.
jbrow1 is offline
Old 09-08-2005, 09:56 AM
Aphinity's Avatar
You might want to find someone with a starter box to give you a little help through this stage. I always found pull starts to be very finicky, and without nearly ideal settings, you'll always have trouble starting it. Once it's broken in and tuned, you should be able to go back without trouble.
Aphinity is offline
