1/8 Ebuggy ESC MOUNT QUESTION
#18
Sometimes its not the tape at all. You have to be sure even before tape it down that the esc wires doesn't push or pull the esc in anyway. If the wires are pushing or pulling it will eventually come off regardless.
#19
well i took my esc and some grey 3m tape and stuck it to a piece of plastic. i then took and added another layer of tape to the plastic and then stuck that to the chassis.
#20
To the guys using adhesive backed Velcro, do you use just the male and female part of the Velcro or do you create a base with double sided tape and place the adhesive backed Velcro on that?
Also, which Velcro do you use? I've got some 3M "heavy duty fasteners" rated for 2 pounds per inch.
#22
I've always used one layer of the walmart 3m double sided tape. No problems yet. If you use alcohol to clean the mounting area and the esc before applying the tape, it will stick "forever". I've cracked a receiver case trying to remove it.
#23
#24
I won't be using a tray on my E Car. I guess I'll just use the velcro tape and check on the car after a few laps. If it doesn't look very good, I might end up using 2-3 layers of double sided tape.
#25
http://www.rctech.net/forum/attachme...per9_lcg_3.jpg
#26
Thanks for the info.
I've never seen a Hyper 9e. It looks pretty good.
