All about Tires!
#17
Can we get some comments going about people's favorite sauce? My favorites right now are sticky kicks blue and WD40. WD40 seems to work best on my slicks at SCVRC, but also works on my treaded tires. I haven't had a chance to really try it at OCRC. I usually clean with Simple green then I sauce.
http://www.rctech.net/forum/electric...ighlight=WD-40
#18
I take a spray bottle and fill it with 8 fl oz of Dawn Dish soap, and the rest water. I use that mixture to clean my tires. Works better than Simple Green. And I swear that I sometimes have more grip when I clean my tires with the Dawn Soap.
As far as traction Compound goes, it depends on the track I'm at and conditions. But so far I use Trinity Blue Dot, White Sticky Kicks, or SXT 3.0
#19
There has been some discussion that WD-40 builds up and ends up ruining the dirt. Might be worth a read.
#20
I use simple green and it works good.
1. i wash the tires with water
2. i spray them with simple green (not diluted)
3. spread it around the tire and let them sit for as long as you want
4. use a towel to dry off the excess simple green (tires should be dry and grippy feeling)
i do this between every round at my indoor clay track. It works good and is much cheaper than a "rc" traction compound. The most important thing is to dry the tires. If you dont they are slimy and have less grip than before you cleaned them.
#22
#24
I've heard belt dressing also works well but can be pretty smelly and toxic? I'm thinking a lot of our tire sauces might be a bit toxic…
I don't mind the smell of Stickykicks blue though
#25
I've used trinity blue and finally gave stickykicks blue a try. I liked the trinity blue, it was quick to dry and the tires felt pretty soft, I wouldn't say sticky.
I'm liking the stickykicks better, feels like I have more even grip through the race.
I've noticed on my medium compound proline suburbs get insanely sticky after just a scrub in a tire wash station with just a little bit of simple green and water. I may have to give the tires a little spritz of simplegreen.
Also any one belted SC tires? I don't get a lot of ballooning but I wouldn't mind giving it a try.
#26
Sticky kicks is awesome for electric classes. It last for almost a 7 minute main. But starts loosing grip afterwards.
Simple green just cleans the surface of the tire. Did not add any extra grip to the tire on track. Bench testing seems softer though. I tried simple green vs regular water with a toothbrush. SG makes the surface shiny, but just water works just as well on track. I avoid SG because I read somewhere it sucks the natural oils out of rubber eventually.
#27
Ok, so I'm running a 22sct, 17.5 motor on a large indoor clay track. I did what most beginners do and bought what most guys are running. Which is ions in super soft on all 4. My question is why? What are the different tread types for?
#28
Let's start by talking about belting. Has anyone done this for Off road tires? I think a few loops of kevlar and a little bit of glue could help quite a bit. It always seems like my car bounces a bit down the straightaway and I think it's mostly due to the tires ballooning.
Here's a video that got me thinking:
http://www.youtube.com/watch?v=C_pXPy2rwTY
Cheers!
Cheers!
I had an old set of tires that were sold on a simple carton/paper box. with windows and all. Hit them with WD40 and they're much softer. Now I just use hot water to rinse them or before using them ala sedan racing style.
#29
The array of tread designs, and compounds, are for different track surfaces, types of dirt, conditions including moisture and temperature, etc. Tires are very track specific, the best tire can even change during the day at the same track.
#30
So what treads work best in what conditions?
