Kyosho Ultima SC6 Thread.......
#1756
Not new to Kyosho but new to the SC6 family! In the process of dialling it in to my liking. In the process of playing with spring rate, my local club track has a carpet in field and dirt / clay faster section which makes dialling in a bit of a compromise.
I have some buggy springs that I would like to try, does Kyosho make taller shock cups so that the buggy springs can be used in their truck shocks like AE does?
W5303-12
#1757
Front hinge pin brace
Found a way to prevent the front hinge pin brace from falling out. The Exotek has 2 m2.6 threaded hole in their bulkheads. Slot the brace with a file / Dremel and the brace can be secured using 2 M2.6 bolts. If I was to do this again I would slot the thinner side of the brace as with then SC6 the brace can be fitted either way. I assume you can tap a couple of holes with the factory bulkhead to do the same.
#1760
I never have had an issue with the front pin holder coming off any of my kits, my rb6, rz6, rt6 or my sc6........ If you have issues the easiest way I think would be to put some silicone on the end of the pin, then put the holder on, as it dries it would make it a tighter fit that would still easily come off with a gentle pull.
I know that the part numbers are different but the arms look the same, what is the difference between the rt6 arms and the sc6 arms? I am in Vietnam and seem to have issues getting RT6 arms, every time I need to order them Amain is either out of stock or only had one or two in stock, but they always seem to have sc6 arms, would they work? I do not have any spare sc6 arms to compare, so for me to do so I would have to take my sc6 apart (arms for both have been ordered)
#1761
3speed transmissoin
A RB 6.6 3 SPEED WILL FIT MID MOUNT IN A RB6 WITH THE SPUR GEAR SIDE ON THE LEFT LOOKING AT THE REAR OF THE CAR
#1762
Question, what combo of inserts are people tending to prefer in the C and D hangers while running mid motor configuration on med bite, bumpy hard packed dirt.
#1763
Do the Tebo front shock tower and the Kyosho UM782B tower have the same dimensions or are they different?
#1764
I have a well optioned up RB6 currently in rear motor set up. Is there a list of what I need to convert to SC6 mid motor. Is this one of those I'd be better of just buying the SC6 buyt the time I bought all the nits and nats.
#1765
Hey guys! I have a Kyosho RT6 stadium truck that I love to run but was thinking of being able to swap parts when I need to to make it a 2wd SCT to run it in short course..Would anyone be able to tell me what parts I would need to turn my RT6 into a SC6? I would drop in the 3 gear stand up that I am using from my rb6.6 buggy into the sct to have a 3 gear stand up sct in mod. Any help is appreciated, thanks everyone!
#1766
Is Kyosho releasing a new kit soon? Would it be a mistake to by a RB6.6 relatively soon? Is it a fairly durable car for beginners?
#1767
#1769
Getting back into 1/10 2wd sct, Need setup help with my kyosho sc6, mid motor, outdoor clay track, medium traction, smooth. Running gridiron 2 front tires, either proline holeshots or HB megagrid tires, short battery with weight under battery. Any help would be appreciated, thank you. Scott
