lipo not fully charging? >
Old 02-03-2014, 09:35 PM
  #16
Jake S's Avatar
Trader Rating: 67 (93%+)
if your 7000mah battery takes 5800mah, thats right where it should be, because you should not really be using really any more then 80% of the rated capacity when you run a lipo down to 3.0v/cell.
normally your battery should peak at 8.40-8.41v when fully charged, i have noticed that once packs start peaking at less voltage - 4.18v/cell that a pack feels softer on the track and is most likely getting to a point closer to the end of its performance life cycle.
Jake S is offline
Old 02-03-2014, 09:43 PM
  #17
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by colewalker500 View Post
ok so i just got done running my battery down with the LVC set to 3.2 and after charging it, it said it only put 4700mah in the battery. any help with this one? should I set the lvc to 2.8 and see what happens? or should i stick with the 3.0 LVC?
How old is the pack?
symmetricon is offline
Old 02-03-2014, 10:00 PM
  #18
huzzler's Avatar
Just ignore the mah. What is the voltage at per cell when you first put it on the charger? Shouldn't be any lower than 3.2 per cell.
huzzler is offline
Old 02-04-2014, 04:10 AM
  #19
As mentioned previously the voltage will rise back up after stopping. Once it recovers, there isn't much left at around 3.7V per cell. In the 3.6V range the cell is for most all practical purposes dead and risks some deterioration. Any lower than that has likely caused damage.
Dave H is offline
Old 02-04-2014, 04:11 PM
  #20
It was at 3.7 per cell and went back up to 4.1 after charging..... i think im going to just leave the LVC back at 3.0
colewalker500 is offline
Old 02-08-2014, 06:15 AM
  #21
dtr
dtr's Avatar
4.1 is too low, why don't you charge till 4.2?
dtr is offline
