Motor spray question..
I actually have used aerosol contact cleaner, used in electronics, to flush out both brushed and brushless motors. Works great, just remember to oil bushings/bearings after.
You want to use this stuff. It is safe on plastic also not all of the sprays are. http://www.amazon.com/gp/aw/d/B000BXOGNI You can get it at Walmart or auto places like autozone or pepboys. I think it's cheapest at Walmart.
I use that stuff for just about everything. It's lexan safe too.
Back in the brushed motor days, I'd have a case in hand at all most all times.
Be careful about what you spray the "plastic safe" electronics cleaner with. I had used it on hundreds of motors and esc's over the years then one day recently was cleaning an esc and the case literally crumbled to dust in seconds. It also hazed the circuit board badly. I had used that cleaner on that brand many times in the past when the company was under different ownership but when I called them they told me (quote "we use the best plastic, it must have been the spray") BUNK. I have since used that spray on dozens of other electronic items with zero issues. Turns out the only plastic it has ever ruined over the decades was that ONE.
