Serpent Spyder SRX-2 Mid Motor Buggy Thread
#1171
The Ackerman change affects the car at all speeds, and was a big improvement on the tight track we ran at this weekend. The rear pivot change will be more noticeable when you're exiting the corner and applying throttle.
#1172
My setup from this weekend's JConcepts SuperCup race:
http://dialedsetups.com/sheets/serpe...-rd-3-1282.pdf
Shout out to Jared for the input. We're making this buggy better each time it hits the track!
Really liking the wide/0 down pivot and wide hexes along with the #3 Ackerman arms. If you're looking for more aggressive steering, try it out.
That helps answer my #3 ackerman question. I want to try this out.
I'm also using the wide rear pivot but at 2 down and just changed it to 1up FR/2down RR wide pivot for a 2 degree antisquat. It helps with on and off power steering for me.
So the difference in your 0 down wide pivot compared to 2 down wide is the lower roll center of 0 down? Doesn't a lower roll center in the rear mean more rear grip which will decrease steering?
#1174
I also switched to 4 hole machined pistons, 1.1x4 in front with 27.5 wt AE oil, and 1.6x2; 1.1x2 in the rear. I think I may try 1.4x2; 1.1x2 in the rear. I was skeptical of the 4 hole piston, but man they are amazing. On a quick transition track it makes a huge difference.
Take Care,
Chris
#1175
That said, I have only tried the wide pivot with the 0-down height, and will definitely be testing more as time allows. A few on the team have settled on the 0-down wide as a predictable setting while still rotating better than the narrow setup. I highly recommend sticking to the wide hexes if going to the wide pivot as well, as it is more consistent and doesn't scrub corner speed much if at all.
The car itself was FAST, and had no problem keeping up.
#1176
A couple more notes:
I have tried out several different 2-hole piston setups, and by far the best combo for me is 1.6 front and 1.7 rear. Have some 4 hole pistons to try on a spare set of shocks but just haven't gotten around to it.
An easy but often neglected setting is the rear toe. Adding .5 degrees of toe at the hubs is a quick-and-dirty way to gain some traction when, for example, the track loses grip as the temperature drops, or in the first round when before it has a chance to heat/groove up. Keep in mind that this will take away a bit of steering, so be mindful of your setup and track conditions.
If trying the #3 Ackerman arms you MUST check your toe first and then EPA on your radio if needed.
#1177
R/C Tech Elite Member
I got to put a few runs on my buggy today in stock. I am/was having more of lack of on power steering than lack of rear bite like it seems everyone else is. The car has great forward bite, and turns in great, but struggled mid corner, and when the throttle is applied it would almost go straight. I am slowly tuning from the stock set-up, so shocks and almost everything else is still there. I did change a few small things and have the car almost where I want it. I raised my front c-hubs (or lowered the spindles) by placing both spacers on top, have my front pivot at 30°, and went to the 1.5° rear hubs inserts, but have them installed backwards to add + toe instead of -. I don't really know exactly what the ° is running it this way, but it appears to the naked eye to be +5°. Car rotates really well w/o any drag brake, and still has all the forward bite it did prior to the changes. I am also running a shorty all the way forward with no additional rear weights added other than a front skidplate I made (aprox 18g). Knocked off nearly 1 second from the 1st heat fast lap (lol) to the main.
I thought the same thing, but it showed up a little later when I quit looking. Mine was hiding in the out drive I think..?
#1178
The above is compared in feel to that of 2dpwn/narrow pivot which I ran before. This change is a bit more involved than simply saying higher roll center or lower roll center. It alters the suspension geometry and is more drastic than say adding or removing a ball stud washer, which should be reserved for fine tuning.
Thanks for the explanation.
For the rear wider hexes, do you mean these: http://www.amain.com/product_info.ph...heel-Hex-Set-2
#1179
The ackerman options really have me confused. If I put #3 on one side and #1 on the other side the tie-rods seem to have the same angles. If I put #2 compared to 3 and 1 I can see the angle of the tie-rod is a bit different. On cars like the B44.2 where you move the inner link of the tie-rod forward or back you can clearly see a change in tie-rod angle.
#1180
#1182
[QUOTE=flame56mx;1312398 I thought the same thing, but it showed up a little later when I quit looking. Mine was hiding in the out drive I think..?[/QUOTE]
Yep found it. I was looking for a red o-ring according to the manual, but it was a clear one. Kind of hard to find on my pit towel.
#1183
I was skeptical of MM being a one and only car, but after watching them perform this weekend in the loose/slick conditions, and high bite I was sold. My buddy Mike McFarlan was able to TQ the first round of qualifying in our class when the conditions were at their worst, and that was proof enough for me.
#1185
Had a good day at the track this weekend, had a bunch of help from JKirkwood on getting the car set up, as there are so many adjustments you can make on this car that I'm not used to. I qualified second behind Kirkwood for the main, gambled and chose the wrong tires so I just had to drift around for a dissapointing fifth. Had third in the last corner but jabbed the brakes too much to get the car to slide out and hit the tube, losing two spots. Oh well. Went to 0 down wide 2 down wide to try to settle the car down in some rough stuff, and that helped a lot. Thanks Jared for your help!
