Serpent Spyder SRX-2 Mid Motor Buggy Thread
#1907
Got my first 1/10 in over 18 years. I finally completed my build and now up to tires.
Just got my AKA tire punch tool. Which size should I use and how many holes?
2mm, 2.5mm, 3mm? Same diameter hole for front and rear? Just one hole or two on opposite ends? (I am using closed cell inserts).
#1908
what do u guys think is a good turn motor for a tiny indoor track?
#1909
#1911
0R - down - 0L it means that once I install my inserts it will look like this?
<-0 <-0
This based on R being wide and pointing to the out, and L being narrow and pointing to the inside, correct?
#1912
Let me see if I get this right. If I look at a setup sheet and it says I need to use
<-0 <-0
<-0 <-0
#1913
Crap! I spent quite an amount of time tearing my buggy last night to make the changes. :'(
Trying to understand how these inserts work. *sight*
So I should have had this?: 0-> 0->
For the FR I installed the 0 inserts, so no wide/narrow here based on the sheet.
For the RR is where I am still confused with L/R
#1914
So back to your buggy,
You want <-0 and 0->
#1915
OK - Re-reading the eccentrics chart again.
Thanks for the info. Let me go back upstairs to my "man-cave" to tear apart the car (again) and make the changes.
Will need to make changes to the front as well.
Appreciate the help.
#1917
Got it... at least this time there is no confusion as I will be using just 0
#1919
Kwiksi: I will take a look at it later today. I am done making the changes.
I just need to set ride height and camber. Eyeballing it, camber looks about right.
For the ride height, I will wait until I run a couple of laps to see if the suspension
settles in.
Speaking of suspension, I noticed after changing the inserts in the back that the
arms does not go all the way down now, as if it is binding somehow. Again, will run it like that
and see if it settles before making any adjustments.
Here are two pics:
settles in.
Here are two pics:
