Serpent Spyder SRX-2 Mid Motor Buggy Thread
#1591
#1592
V1 pictured here making a new one in the morning that is raised so i can put the battery back a little more.
Also latest gear design
#1593
Mine will be here tomorrow...
I need to know, what spares will I need as my hobby shop doesn't stock serpent
#1594
- front hubs
- front arms
- rear hubs
- the tiny shock mount nuts
- ball ends
I havent broken anything but the front hubs and ball ends wear out and get sloppy and i had a stud pull out of the rear hub
Oh and get the aluminum steering rack!!
#1595
Is there a reason I can't find the ball ends on a mains website?
#1596
#1599
ok thanks ! assuming my car is bone stock, what other option parts are recomended by any of you fast stock guys. I plan on tranny gears and lite top shaft, but all other suggestions are appreciated. Since i run on carpet, "should" there be any gains in performance from adding sway bar(s) ?
#1600
#1601
Gear diff and front/rear sway bars helped me a lot on the carpet. I run CB's Custom cut gears and was fine in stock.
I also went for the aluminum bulkhead so I can change caster.
#1603
What gains are you seeing with the turnbuckle rear brace? More rear grip on power?
#1604
#1605
Are you on Facebook? Join the serpent Spyder group. There were a few posts recently about this about a track in NY.
