Schumacher Cougar KF!!!
#436
I did some testing today and tried running 3 degrees neg camber...it did seem to help. I was able to run enough laps to get my tires broken in to a much more usable state and I saw lap times as good as I had been running with my SV2 begin to come around by the end of the session. I also added weight on top of the rear camber link plate as much as 1.5 oz and settled on .5 oz I am still running the gear diff with the 12,500 oil and plan to try some other weights soon, but I like the way it drives right now. This car jumps extremely well and is very stable. Corner speed through long sweeping sections is superb.
Corners where on exit the risk of over steer coming in were completely removed and meant that mid to exit corner speeds could be kept 20 - 40% higher depending on the tightness of the corner
Definitely keeping with 3* from now on until environmental grip levels come
#439
On properly broken in tires and with a few more laps on the KF, I manged a tie for 1st in mod buggy and with the tie breaker a 2nd overall. My fastest lap was a 16.9 which was my previous best with the SV2, so I am definitely seeing the potential to get even better with more time on the KF. Keep in mind that I am running the car nearly box stock other than 25 wt oil in the shocks and a 1.8 rear spring. Rear shocks all the way inside on tower and 1/2 oz on the rear camber plate....that's it, the rest is kit setup!!! This car is DIALED guys.
#440
#441
This is our track
#442
Are you talking about axial play (side to side), radial (like duff bearings) or rotational play like excessive backlash?
#443
It seems to have side to side play, Only a very small amount but it seems like just enough to make it have that small issue when initial mesh from a stand still, I'll have a play around with the mesh and see if I can tune it out a little. Awesome car to drive though! I just ordered a K1 aero to go with it
#444
Did some testing today on a carpet off road track and was really hooked up. Amazing corner speed and the car inspired confidence to drive hard. Still same base setup and car felt great. This car definitely shines on carpet, but has also been working extremely well on clay. All I did was lower ride height to 18 mm and moved rear shock out to middle hole on tower. Ran yellow mini pins and low pro cut stagger...dialed
#445
What is the belt pitch on the KF?
#446
I tried the high inertia side gears U3861 and U3866 and found this also helped with rear traction, this was on wet and greasy astro. I could nail the throttle without any real issues whereas with the standard side gears I had to feed in the power otherwise the car could swap ends.
#448
I also have an SV2 and really like it as well. I would never let my KF completely replace my SV2, because in my experience it simply has more rear traction for lower grip tracks. It seems to me that Schumacher gives us a choice of platforms for specialized purposes across their range. With that being said, I have gotten the KF to work quite well on med/high bite clay and then turned around and ran it on carpet the next day...
#449
Think I'll get the 12mm hex conversion for my SV2 and accidentally drop a "KF" in my basket as well.
