Weird ESC issue. please help before the weekend!
#32
more than likely its a quality thing. the the rx8 out of your ebuggy and try it, lol. I have never owned the Chinese brand motors. I only run sensored reedy/tekin motors. I have had sensor cables go bad with my HW esc and the esc switched into sensorless mode and it still ran super smooth. But I did see delays if I did a full punch of the throttle. But when I accelerated smoothly, I didnt really see a huge lag. Are you racing that truck?
#33
Thanks for everyones input!
#34
If reverse works fine, the motor wires need to be switched and the channel reversed on the radio. Only switch 2 wires going to the motor.
#36
Just a thought to help reduce the problem a bit, would be to turn the throttle trim up a bit. That will make the throttle a bit more responsive down low. You might be able to eliminate the issue by adjusting the trim until the car moves just slightly on its own. Again, worth a shot.
#37
Does it hesitate any when taking off at half throttle?
#39
#41
Something in a slight bind would be my guess, making the motor try to pull more current at takeoff. Dropping a few teeth on the pinion would probably help that. Of course the ESC may just be bad.
#43
Its not binding. The same exact thing happened to me and my friends sc8. Our solution was to swap the ESC... Was your ESC overheated? We ran ours in grass one day and ESC thermalled. And after that we had a delay of a second or two when trying to start off from full throttle...
#44
Guess I know what I have to do. Thanks for the reply!
