Team C TM4 4wd Buggy Thread
#61
I believe you are talking about the old Caster design...which IMO was crap. The new 2 pc while not really groundbreaking or innovative is MUCH more functional.
Say what you want but that center cluster is just another slight derivative of those designs AE, Caster, HB or whoever.
That said I like a lot of the things I see in your build there. Shorty, CF top plates, the outdrives look good. I wasn't intending to knock the Team C car at all. Looks nice to me.
Its all good man, no worries! no matter what design it is we still have to drive it
#62
They changed that rule months ago, we went through that with the TM2 and it ran almost every major ROAR event last year.
I guess you could probably do that but really no point, The TM4 ran at the worlds in its current configuration. You cant run anything other than saddles in the new Losi because of the belt so by old rules its not legal either!
#64
#65
either way the rule no longer exist, both of these cars are ROAR legal.
#66
Now it just creates confusion.
#67
Not shorties specifically. I think the rule predates short packs. The spirit of the rule recognized that lipo shape was easy to change and therefore companies could create proprietary shapes and drive the prices up. Neat theory but in reality either the cost would turn people away or somebody would create a real advantage, the platform would become popular, and the aftermarket would provide a less expensive alternative, just like happened with Losi's shorty packs.
#68
the rule allowed saddle packs, the rule was that the chassis must be able to accept a battery of a total length of whatever the dimension is, I think the total length is in an amendment somewhere, but when you lay a saddle pack end to end its the same total length of a standard pack which meets the total length requirement, it doesn't matter where the two peices are moutned and technically you could have 3 or 4 peices as long as their lengths added up to the required total. Its kind of like the old rule about 6 cell, you could have the 6 cells mounted in totally different areas but you could only have 6 total cells.
now whether or not this rule has been changed I have no idea, It should also be noted this is only for ROAR, IFMAR doens't have this rule which is why it didn't matter for the wolrds. I personally dont run any ROAR events so could care less,
I started my build last night and so fas so good, the machined orange parts on this thing are beautifull, and everything has fit perfect to this point, I've got a little binding in my rear diff I need to try and look at tonight, but I think thats just something got built wrong lol,
#69
Check and see if the rear center cvd is binding on the slipper outdrive.
#70
I dont have the slipper in yet I'm just to the end of Bag B with the bulkheads bolted to the chasisis, It was free when the bulkhead was all bolted together outside of the car but when I bolted the bulkhead down it got a little tick in it, I'm thinking something just went a little off centre or maybe one shim to many or something dumb like that but I didn't really look at it last night,
#73
I had to run different shims front and rear for now, it will change once I run it though. my tick ended up being 1 too many shims under the pinnion gear so when I tightened the case on the bulkhead down the mesh was slightly too tight. problem is I stripped the screw holding the pinion on so I can't get the shim out lol, its just a small tick so it should wear in and be good to go till I can get time to drill out the screw, hopefully swap out the machined gears down the road
#74
I just ordered one of these through my local shop who is a HRP dealer, cant wait! car looks awesome! I saw that it was ran at the worlds and maybe reedy race but cant find anything on how it did or what the drivers said about it. Is there any race info out there?
#75
This is very little video or photos of this car as of yet. I just got my TM4 done today...just need to finalize tire inserts. My LHS ran out of my favourite AKA red inserts for the tracks I run at.
