Team C TM4 4wd Buggy Thread
#47
any other info on this vehicle?
saw pre-orders on Evoloution hobbies.
My Mad Force VE has 14mm hexes.
this car seems to be on the level.
seems to be a nice influx of 4x4 buggies this year.
losi, hb, and this one seem to be the rides, but on a 4wheeler parts are the key before i will make a decision.
so now it's making the most inform choice and i just kike shorty packs better.
somethn' one of these can not except but will have more local readily available parts.
#48
What are you wanting to know about it? Hrp dist has picked up team c and will be the American distributor for kits and parts. Team drivers are working on getting there local hobby shops to start stocking team c so parts will be out there. Its hard to compare against some of the other buggies because I haven't physically seen them but I can tell you this new tm 4 will definatly be competitve and a quality piece. I just built the tc02 evo and I was more than pleased.
feel free to ask any questions and myself and my team mates will do what we canbto answer em
#49
tm4
I am interested in this buggy. Is there a link to any videos so we can see how it handles? How is the steering compared to others, in terms of responsiveness and oversteer/understeer? I don't know why this buggy is getting so little attention. Best looking 4wd I've seen.
#50
#52
http://www.youtube.com/user/Mantisworx?feature=mhee
#54
I don't know how these companies interrelate but that motor mount and slipper support looks like it's right off of the Caster S10B V3 and earlier(not saying this car is a direct copy as there are some obvious differences). It really is a weak design and the newer 2 pc design that Caster is now using is WAY better.
#56
Shorty only, the motor mounts longitudinal on the left with battery on the right.
I just finished my build, only thing left is electrics. I have built dozens upon dozens of TeamC kits and this one by far is Stephen's best work! The team drivers get the first run and then they are going to tweak a few things before the general public gets them. I love the insert adjustability on the front kick up as well as the rear anti-squat and toe. Droop screws are also a nice touch. 4mm towers will never break and having the ability to get the diff out with 4 screws is great for quick fluid changes. Only issue i came across was the rear center cvd is about 1mm too long and touches one of the outdrive screws so i belt sanded the CVD for clearance
Other than that its gorgeous!! Jason, mine did not come with the new gears, not sure if they are ready yet but Me as well as the rest of the team have been flooding the emails about it!!
#58
Not a copy, it is the design used off of the TS4 Sc. The T4 had a 2 pc eccentric design which was ok but had clearance issues with the taller "stock" gearing. I have been using the current design for a few weeks now and have had no issues at all. easy to adjust mesh and does not back off. If you want to be technical about the the Caster design comes from the old D3 and b44, nothing new or innovative from them either. Remember i used to drive for Caster and I actually built Mikes car for him!! And this car as well as the T4 are both higher quality especially the plastic formulation. TeamC is a much bigger company and has way more models including on road and nitro. With that along with very high level drivers( Oliver and Hugo) ultimately you end up with a better product.
Say what you want but that center cluster is just another slight derivative of those designs AE, Caster, HB or whoever.
That said I like a lot of the things I see in your build there. Shorty, CF top plates, the outdrives look good. I wasn't intending to knock the Team C car at all. Looks nice to me.
