TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
Here is the setup that Dustin and I ran this past weekend at CRCRC.
Let me know if you have any questions.
JP
JP
I have the -2.5 chassis the bell cranks and brass rear pivot, side pod weights in the middle and rear of the pod. i have my setup to the surf city setup but i dont have the weights for the side of the battery, is running a square pack going to be to heavy should i just run my shortie?? med to high bite indoor clay, and i am in mid. what will the car do with each?
+1
From what I've seen and experieneced, all the "big wheel" stuff has less grip and less consistency on medium to low grip stiff. Seems to only work better on really high grip, like a sugared track or a track where you run slicks for example. In the "spec" classes, sometimes the advantage of less rotating mass is more of the benefit than the loss in grip.
Car felt very planted, smooth, and easy to drive.
JP
i recently decided the 22 2.0 is my next car.
i started reading on page 600 of this thread and i'm not allowing myself to buy the kit until i catch up.
hoping to learn as much as possible before starting the build, still deciding between MM or RM, but i think this guy convinced me:
amazing logic, i agree
Good choice, I think it's a great RM car. MM? Not so much. My opinion though. I ran a B5M before this car which is a good MM car if you want a MM for the dirt without having to add weight everywhere to make it work. I wanted to go back to TLR though, and I wasn't going to monkey with trying to make a MM TLR work. I am very happy with it in RM.
I tried the MM and couldn't get it to work the way I felt it should. Just didn't feel comfortable for me. Went back to RM and swear to never go back. But the pressure from everybody else is intense! I think they are just trying to slow me down so I wont be a threat
But I do see the advantages of the MM and yes, they are just as fast.... in the right hands..... just not mine!
jp or frank,
A few posts someone asked about the shorty vs square. Wondering if it is the placement of weights vs the total weight that makes a difference? I run mid with the saddle packs and while it is almost the same total weight as the shorty with 20 grams on each side and 18 grams each side pod, I was wondering does the weight being out farther with the side pods make a greater difference?
jp or frank,
Worded much better then i did!! That is what i was getting at with my question.
