Hot Bodies D413 1/10 4WD Buggy
Tech Legend
Tessmans setup at 20K-100K-5K all AE oils.
I may try 10K in the rear instead and leave the center alone. Eventually work my way towards Ronnenfalks setup I am thinking.
I'll also be reaching out to Exotek on there front hexes as the screw is not grabbing anything on one of them, I can literally drop a pin clear through with the screw present.
Thanks Cain, I ordered a .3mm thinner front sway bar last night. I'll try that and if it gets better but not quite there I'll try no front sway bar.
Tech Legend
My other exotek chassis came in, excited to get that put on for my daughter. Was going to order the braces but I screwed up my order so I think i'll just try modding the stock braces.
Hello Yeti AS3,
Thank You for Your pic. But as I browse around A-Main, it seems that there is no specific Open Cell Foam for Front Tire available. Most of the Pro-Line 1/10 Front 4WD Tire are comes with the Closed Cell Foam Insert.
Cameron Kellogg suggested me the use the Open Cell Foam Insert, so do I just buy the Wide/Rear Open Cell Foam Insert and cut them to fit the Front Tire?
Cheers..
Cheers..
Hello Cain,
Thank You for sharing Your thought, but unfortunately the 1/10 is just starting to be popularized again. So, there is still no good reference about tire.. Hahaha..
As for the Open Cell Foam Insert, any suggestion for which brand that is good??
Cheers..
Cheers..
Hello Yeti AS3,
Cheers..
Cheers..
Tech Legend
For tires, if I was starting up, I would probably go with:
All green compound:
- JConcepts Double Dees
- JConcepts Flip outs
- JConcepts Goose bumps
that should cover a variety of "dirt" conditions you can see.
Anyone know where to get the latest setup sheet from that the carpet setups posted are using?
I use the white open cell foam inserts that come with the Jconcepts tires. The fronts need the width trimmed off about 3/8 as they send the 4w fronts with rear inserts. I tried dirt tech and AKA and Proline inserts. Any other surface closed cells rock over open cell. Loose dirt bumpy track open cell was so much more planted, consistent, and faster to drive. I could push the car so much harder and drive complete packs without marshaling. I thought maybe because the double Dee was designed before closed cell inserts that the tire is just better suited for open cell but I tested AKA impacts with red and then open cell with the same results. Open cell again way better. Just figure the open cell is like lowering your tire pressure and allows the tire to flex over the bumps instead of bounce. Also makes for a greater contact patch with the track and increase bite in corners. My times with open cell was a full second faster a lap on a 22 second track. The next biggest change I Iiked was the new caster blocks with the inner hole. Made the steering so much more consistent on and off power. Really seemed to be able to get on throttle more and drivesteer on power through the corners. Such a fun buggy to drive outdoors.
Cain try and make yourself some 2.0 and 1.8 sway bars for the carpet track. Should help.
Hello Cameron Kellogg,
I will try to find the front Open Cell Foam Insert for the Front Pro-Line Tires then. Because most of the Front Tire comes with Closed Cell Foam Insert.
Cheers..
Cheers..
Tech Legend
Do you know if there was a particular part from another car that was started with to make some or is it going to be fully from scratch?
Well with the stock shock caps i went with the Emousion style did not need to drill i just prethreaded the bleeder hole with the small screw on top and there was a clear opening inside .
Oil came out good .
Gota say these are some smooth shocks even with chrome plated shafts much smoother than the stock ones on my B5M even with better o-rings .
Oil came out good .
Tech Legend
they are pretty smooth. I got two sets one with the the HB alloy caps and another with the Exotek caps. seems I can get a closer to zero rebound on the HB caps a tad easier but they are both excellent quality.
Quick question on weight. I had by d on a 4way scale, and the battery side was significantly heavier than the motor side. Front to back was ok, but side to side the weight bias was terrible. Off about 100 grams. Anyone else ever look at this?
Tech Legend
Maybe that woudl give you better balance you are looking for (then add weight to the front as needed, Durango had Servo centered so didn't really need that just ran the receiver and transponder under driveshaft, centered)
I didn't notice any weird weight issues when driving the vehicle however.
If there is one thing I really don't like is the Rear shocks mounted up Front of the Rear arms its a pain to loosen and tighten the bottom screw . Can you flip the Rear arms and have the shocks in the back ?
