Hot Bodies D413 1/10 4WD Buggy
#9438
The wheels do a great job of holding the pin in place. Seems as the buggy was designed to be used with wheels on it. So why do you guys keep taking them off?
#9441
That being said, I just put a little blue loctite on the drive pins and they stay in place for me.
#9442
A small dab of shoegoo on the end of the wheel pin. It will stay in place, but as soon as its time to remove the pin, it will push out easily. Usually the shoegoo stays in the hole/hex when you remove the pin, and when you install the pin again, it will press back in with just a little resistance, enough to hold it in place.
Locktite would work too, but be careful. If you use too much it might be really difficult to remove the pin. If you use way too much, the Locktite could get into the outer hub bearing.
I'm pretty happy, we just got the first layout built at the brand new indoor track that is opening in my area. I got to run about a half a battery through my B5 rear motor car. The dirt was compacted, but not watered yet, so it was pretty slick. I threw some JC Goosebumps on the car, and it was actually drivable. The clay compound scrubs up front didn't work very well, even still, with only a blinky 17.5 the car was the fastest around the track. Hopefully my new D413 will be turning its wheels in anger very soon.
#9443
Most in our area usually take them off to scrub and clean them with simple green before the next round or to put new set of tires on or different tread pattern... LOL
I use a small dab of shoegoo on the pin and has been working great since last September.
#9445
#9446
My name is Micahel Deeger and my friend Michael Pease bought one of these cars....what does he need to do?
#9447
Michael pease broke his input shaft
#9449
He broke his center driveshaft input shaft and needs help. He's thinking of replacing the ring and pinion gears with ones from the b44. Does anyone know if they will fit?
#9450
Does anyone know if you can use piano wire to make sway bars for this car? Pease made new arms out of cutting boards.
